Question about IBM ThinkPad T21 Notebook
How do i get the screen off my ibm t21? My led is very faint and I think I need to replace it.
Screen is dim, worked great up until a month ago. I want to take off the screen and replace it, unless you have another solution?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
I'm afraid you replaced the whole screen when all you needed to do was replace the inverter, which is much simpler to do. Virtually all LCD screens light up with an inverter. Usually, they just go blank blue, though; I'm puzzled about the "dim" manifestation. Call IBM help--they have foreign accents, but are usually quite knowledgable.
Posted on Mar 02, 2008
I had the same problem, and managed to fix it my replacing the whole screen (inc. laptop lid) from another broken model. It's not for the fainthearted I'm afraid.
I since discovered, the problem (if you can see the display, but it is very faint), the problem could be the screen inverter which can be replaced without removing the screen from the laptop chassis. (there are a few guides available on the internet to do this) I've seen a few of these items on ebay for not a lot of money (£10/$20), and changing it should be much easier.However it could also be the backlight itself as well.
google "Laptop Repair Help Screen inverter replacement" to get an idea of this problem , and possible solutions
If you want to do what I did(good luck!!!) you have to take quite a lot of the machine apart.
1) Close laptop and lay it down on it's lid(bottom facing upwards).
2) Remove battery.
3) Remove EVERY screw you can see on the underside (even the one that holds the cmos battery(as I think it doubles as an anchor for the keyboard). Most are small crosshead, but you may need a flat top for one or two.
There are also 'hidden' screws - on the front edge(3 I think) and either side of the back (where the usb/video ports are)(2). The panels that hide these look like little plastic square blanking plates. These just pry off(they are just stuck on, the screws are behind them) I would hold off removing the ones off the back (4 screws) for the moment as these attach the screen to the chassis
4) Once all screws removed, turn laptop over and open it up. You should now be able to prise off the keyboard (use a small screwdriver or knife to get under the keyboard, it is held by a connector towards the centre but, should pop off provided the screw from the underside is removed.
5) Once keyboard is off, there is one screw to remove, which holds the screen to the motherboard, and one or two others securing the rest of the keyboard surround.
6) Remove the keyboard surround, and you should be able to see the anchor points in the left and right corners of the laptop chassis (under the screen).
You should then be able to remove the last 4 screws from the back of the case (the hidden ones). Screen should lift off. Then do the opposite to put lid back on.
phew!
Posted on Dec 20, 2007
  • 383 Answers
Computer tips relating to Microsoft Windows When shutting down or turning off the computer you'll get three options: Standby, Turn Off, and Restart. For users who wish to hibernate their computer you ...
Should get ya shut down, click on the link above and follow instructions. Please dont for get to Vote.Thank You.
Posted on Dec 15, 2007
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
Xl 2400 replacement bulb---dim after replacement
did you use a genuine sony replacement bulb or aftermarket? Often the aftermarket lamps are not up to par with the OEM versions.
Nov 01, 2012 | Televison & Video
My Eiki lc-xb33 is projecting the image from my computer very dimly. Although the image is in focus, it is very difficult to see the image at all because it is so dim. Even the blue start up screen is...
You need to remove the cover and check where the lamp light is being attenuated in the optical path from the lamp to the front lens. I would try using a 12volt 50W halogen lamp in place of the real lamp and shine it into the optics system, and see where the brightness starts to go bad.
May 11, 2011 | Eiki LC-XE10 Projector Multimedia...
Hello, I have a Compaq CQ60 and have problems with the LCD display, which works intermittently. I had the entire LCD replaced about 4.5 months ago. Worked great until a couple weeks ago, the LCD went...
is this a CCFL LDC
if yes the inverter is bad. (a card tiny, and thin)
its old LT.
the books are gone now.
the service book tells you how to replace the CCFL inverter
find a used good one is problematc.
why not buy a newer LT
or just run the external screen and be happy
I guess you have not read the user guide yet?
about the VGA hot key.
mine has.:
1: external only
2: internal only
3 both
4: auto. (i think only my newer HP has this)
mine is Fn+f4, but on a relic compaq, gee buy the book,
or google search for it for weeks,
next time post to HP< there is no COMPAQ for years.
hp owns it. totally
ever seen this before. the fail like LT batteries do. often.
http://www.ebay.com/itm/New-15-6-Laptop-Screen-LCD-Inverter-for-Hp-Compaq-G60-G50-CQ50-CQ60-Series-/251312052451?hash=item3a835d98e3:g:ARYAAOSwal5YJoxR
search there "compaq CQ60 inverter"
bingo.
when the sceen is dead do this.
see the flash light here, BINGO? bingo for inverter *****?
http://pcdied.com/black-screen.html#Dimbulbs
Mar 23, 2017 | Compaq Presario CQ60-212US Notebook
Part of my ipod screen cracked a few months ago ( i got grounded and my sis played with it T.T ) and now then left part of my ipod screen won't work examples : keys that won't work : q, 1, -, _ , and [. i...
your best bets is nipping to a comp/phone shop and getting your screen replaced, you could try ringing apple but i doubt your within your warranty anymore unless you extended it and they can charge upto £146 depending where you are. No offense but i wouldnt try to replace your screen yourself unless your absolutely 100% confident you can, a lot of people do it and tend to do it wrong and end up with a white screen - which pretty much breaks it.
Feb 05, 2011 | Apple iPhone Smartphone
Worked great until a couple of months ago. Have
You can see network key by logging in to router settings. Some routers are 192.168.1.1 and some are 192.168.0.1. All you have to do is type it in to address bar on any browser and log in and under wireless tab it will give you field where it says wep or wpa encryption and this is what you need. Hope this helps.
Feb 15, 2010 | Dell Inspiron 1501 Notebook
Dim screen
A New Backlight, or new bulbs for your backlight..
Jun 09, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Vertical lines across the screen
Change ballast and lamp at same time. Ballast #75006507 lamp #23311153
Sep 11, 2007 | Toshiba 46HM95 46" HDTV
IBM ThinkPad T21 Notebook Logo
437 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
