Question about Sony KP-53XBR45 53" Rear Projection Television
No video, timer/stanby light blinks
I have audio, but no video. who can i get to repair this?
I don't know if this will help or not, but I noticed mine starting to do the same thing lately, audio works fine when I turn the set on, but I get no video. I noticed that when I pull the front cover to get to the Light Intensity and Focus controls (G2 controls, I guess), and give just a slight turn on one of the knobs, the video comes on, but then I have to turn the knob back to where it was, to keep the colors right. It gets to be a real pain after a while...
If you have already had your set repaired, please share the solution!
Thanks.
Posted on Mar 24, 2008
Sony trinitron stanby light blinking 5 times
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
For more details type in this site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search or press Enter. It is an electronic equipments service help site.
Note the position of hyphen in between words in site name. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site name, either at the bottom part of first search page, or at the top of second page.
Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price and more.
Jun 05, 2012 | Sony FD Trinitron KV-32HV600 32" TV
There's power but it wont turn on? stanby light okay. Blinking intermittenly.
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
May 11, 2010 | Philips 42PFL5332D 42 in. LCD Television
After filter cleaning of a Sharp Notevision PG-B10S arose the following trouble: I turn the power on, during the warming up the stanby and power buttons go to green light, then after 10 seconds the power...
If you navigate through the projector menu you will most likely find an option to reset the filter timer. Resetting the timer will cause the indicator light to stop blinking.
Jan 18, 2010 | Sharp Notevision PG-B10S Multimedia...
Power light blinking
Send it for repair. The receiver has a problem with power supply or a bad channel.
Oct 05, 2009 | Denon AVR588 Receiver
Stanby light flashes 5 times breif pause then flashes 5 times again
Jul 20, 2009 | Sony Televison & Video
Stanby timer light blinking
you need the V26 DM kit which will usually cure that issue. Its chaep and contains the Replacement capacitors and step by step instructions. Heres a link to the correct kit.
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
Jun 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
SONY TV MODEL kv-27s40 BLINKING RED LIGHT 2 BLINKS
The 2 blinks usually mea an over current problem. Perhaps the most common cause of this is a shortde Horizontal Output Transistor (HOT). If you can solder, you should be able to repair this yourself. Realize that there are potentially dangerous high voltages present inside the set even when unplugged. Look for a 3-legged ransistor attached to a heatsink close to the flyback (part with large red wire coming out the top). The part will be marked C5438 or something similar. Post that marking here nad I'll confirm the entire part number.
Keep us posted.
Dan
Feb 23, 2009 | Sony KV-27V42 27" TV
Toshiba 32wd98b
Hi
Problem is probably PSU REGULATOR, STRF6668B.
I wouldnt recomend you repairing this yourself as there may be other components that will require checking.
You could end up blowing the replacement regulator.
http://dysonmanuals.llc.nu/
Apr 12, 2008 | Televison & Video
Sony KV30hs420 0 Stanby Light Timer Blinks 3 times and powers TV off
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. If you have electronic knowledge you may be able to fix it. Let me know if I could help you further.
Hope this helps.
Jan 25, 2008 | Toshiba CN36X81 TV
Televison & Video Logo
29 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
