Hotpoint 24 in. HDA3400G Built-in Dishwasher
Problem for Hotpoint 24 in. HDA3400G Built-in Dishwasher
I have a dishwasher Midea
By hcelestijn on Sep 22, 2009
I have a dishwasher Midea WQP12-9242 wich is not working properly it shows the E3 error code. What action should i take to fix this?
Comments:
Sep 22, 2009
- Dear sir i have a Midea dishwasher not a hotpoint pls double check!!
Henry
Solution #1
posted on Sep 22, 2009
Not Rated)
ginko
Rank: Guru  Hotpoint Expert
Rating: 89%, 5252 votes
I did not find the model number.
Try first unplugging the appliance power cord, or tripping the circuit breaker, to disconnect power for ten minutes or so.
If that does not clear the error, then F03, or A3 on Hotpoint dishwashers means Wash thermistor open/short circuit, the thermistor must be replaced.
If you have a Kenwood or a re-tagged washer , E3 still means bad thermistor. This time E3 is displayed.
Solution #2
Not Rated)
charlymonty
Rank: Wiz
Rating: 82%, 247 votes
midea dishwasher instructions:-------
E1 :---Cause:---- Water supply switched off.
---- Remedy: Switch off appliance. Turn on water supply. Reset the cycle.------
E2 :--- Cause: Problem with electronic temperature control.----
Remedy: Replace the control board and heating element.----
E3:---- Cause: The water heater element does not work properly or the filter mesh is blocked.---
Remedy: Clean the filter mesh and if the problem continues Replace the water heater element.
thanks.keep updated.please do rate the solution.thank you for using fixya.
Popular Solutions for Hotpoint 24 in. HDA3400G
Questions and Unsolved Problems for Hotpoint 24 in. HDA3400G
Do you recommend Hotpoint 24 in. HDA3400G Built-in Dishwasher?
Answer
Answer
My Hotpoint dishwashers water stopped turning on. It has worked fine in the past but all of the... (More)
Answer
Dishwasher is making a buzzing noise during the wash cycle and the dishes are often covered in dried... (More)
Answer
clip broken off detergent loader container, container will not clip shut.
Answer
how do i drain the macerator connected to my toilet, it has broken and needs to be changed. this... (More)
Describe your Dishwashers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
