Frigidaire FRS26H5AS Side by Side Refrigerator
Problem for Frigidaire FRS26H5AS Side by Side Refrigerator
My Frigidaire refrigerator side by side is freezing drinks.
By kyoro4 on Sep 22, 2009
The refrigerator side is freezing all the drinks on my top shelf. I have put the setting below the factory setting now, but no luck. Also if I don't keep the meat keeper on warm everything in that drawer has frozen in the past.
Comments:
Sep 22, 2009
- The fan is running and the cold air does not seem to decrease when the temperature is adjusted. Does not appear to be any way to mechanically adjust so I guess the temp control may be broken.
Best Solution
posted on Sep 22, 2009
Very Helpful)
woodchuck789
Rank: Guru  Frigidaire Refrigerators  Expert
Rating: 91%, 642 votes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Frigidaire FRS26H5AS Side by
Questions and Unsolved Problems for Frigidaire FRS26H5AS Side by
Do you recommend Frigidaire FRS26H5AS Side by Side Refrigerator?
Answer
Answer
The frig has completely defrosted and then cools down again. When it is no cooling there is a... (More)
Answer
refrigerator is cold but everything in freezer unthawing. Also the outside of the strip seperating... (More)
Answer
Icemaker lever will not cause ice to release through the door
Answer
while my car start running i hear the wind voice in a noisy matter, some times i think that may a... (More)
Answer
Frigidaire FRS26H5AS Side by Side Refrigerator problem water dispensers leaks at where you get a... (More)
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in Newport, KY
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
