Question about Dryers
Outdoor outlet Our outside oulet which our minimal christmas lights are plugged into, stopped working.  I tried to reset all of the breakers, and there is no BFI button that appears to control it.  The house is about a year and a half old.  Any ideas before I call in a pro?  Husband is going to be home for just 13 days for Christrmas before returning to Bagdad, and I really want the lights on to greet him when he gets home. Giner
  • Ginger Caruso Dec 15, 2007
    Oops... I meant to put in my comment that therer is no GFI on the outlet (I wrote BFI by mistake.)  Could it be elsewhere?
  • 99 Answers
If this is an outdoor outlet and was built a little over a year ago it will most likely have a GFI (ground fault interrupter). There are two push buttons right on your outlet. By pushing one of them it should reset it
good luck-------------tomtaso
Posted on Dec 15, 2007
Electrical outlets in my 98 skyline fifthwheel stopped working.but there's power going out of the breakers
This is an indication of a failed connection. Somewhere. Since you probably do not know how the affected circuit was run, it's going to take some time - but it's not difficult work. But before we roll up our sleeves - first locate and RESET any Ground Fault Interrupter (GFI) type outlet. If any fail to reset - replace it with another GFI outlet with the same electrical rating. Pay attention to which cables and wires that are connected LINE and LOAD terminals wires when removing and replacing! Don't forget to check outlets on the outside of the 5th wheel.
Circuits fail almost always at connections. Wires and cables in walls don't just "break" in the middle. We need to check connections in the bad circuit. First, plug lights in all the outlets. Turn the circuit breaker for the bad circuit from ON to OFF. Note which lights shut off. With the break OFF, check the outlets that WORKED.
We're looking for the point that power entered the outlet box, but due to a failed connection is unable to leave it and feed the first failed outlet. Check and tighten all screw terminals and wirenuts. Check both hot and neutral wires. Make sure no wires are loose, pull out or are burned (cut and strip back these wires and reconnect / wirenut). Try to power the circuit to see if you found the problem after each check - if not - repeat at the next outlet that worked until you find the problem. If you are still unable to get it working after checking the working outlets, repeat the process on each of the non-working outlets. If still unable to get it working, check ceiling fixtures as it is not uncommon to wire to the light fixture first and then feed down to outlets.
Feb 02, 2016 | Electrical Supplies
If there is no power for either the washer or dryer, is there an internal fuse or reset button
I assume you checked the circuit breaker for this outlet? Both appliances are plugged into the same outlet? I would try unplugging both appliances then attempt to reset the breaker again....throw it completely to the OFF position, wait 10 seconds and throw it to the ON position. At this point we are assuming the breaker is working. It could actually be defective. It could be tested with a meter or test light. If you don't have that try plugging a lamp or another device into the outlet the appliances where plugged into. If it works you know your breaker, wiring, and outlet work. If not you need to troubleshoot that...perhaps a ground fault breaker somewhere in between? If the outlet works with the test lamp, next plug in one appliance at a time to try to determine which pops your breaker.
Feb 06, 2015 | Dryers
Digital and mechanical timers that are part of a low voltage outdoor light system. Plugged into 120 volts ac outside in a sheltered area. Both kinds of timers consistently fail in the ON position. A timer...
1) Install arc fault breaker to the circuit and remove grfci
http://waterheatertimer.org/images/How-to-wire-GFCI.html#arc-fault
2) Test outlet with circuit analyzer for correct polarity and grounding,
Make sure there is not dual gfci protection on same outlet.
Move wire to different same-size circuit breaker.
Run another line to the same location.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 21, 2013 | Hardware & Accessories
My fridgedaire window unit A/C and heat won't come on. I had replaced an outside light fixture a couple of weeks ago and had turned off the circuit breaker that affected this unit too. Now the unit...
Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
May 22, 2011 | Frigidaire FAS257S2A WallWindow Air...
MY BREAKER BUTTON WILL NOT RESET ON 2 TIMERS AT THE SAME TIME?
You posted under Intermatic plug-in outdoor timer.
If I understand correctly, you have two of these timers plugged into outdoor outlet, and the breaker for this outlet will not reset.
Cause can be 3 different problems
1) Load exceeds breaker capacity. Add up total watts and divide by 120V to see if breaker amp size is correct.
2) Loose wire or short in timers, outlet or wires going to Load. For example a broken outlet, or loose wire inside outlet box, or extension cord is under snow or water. Unplug everything, including timers, and try re-setting breaker again. Plug everything back in one at a time to observe when breaker trips.
3) Bad breaker: Move breaker wire to another same-size breaker and see if problem contuinues.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 06, 2011 | Heavy Duty INTERMATIC 6 Outlet Outdoor...
Everytime we start the machine the oulet goes off ? is the washer or the oulet problem?
First plug the washer into another outlet. If it runs then outlet or breaker problem. If the washer doesn't work there then there is probably a short or too big of an amperage draw. Call a technician in that case.
Dec 15, 2010 | Kenmore Front Load Washer
I want to use an X-10 Pro appliance module outside, in an outlet that has a Leviton outdoor covered electrical outlet cover. The appliance module does not fit even with the cover completely open. Is it...
Instead of trying to put your appliance module outside, and risk it getting wet, why not add another outlet inside the house, near the existing outdoor outlet, or anywhere along the path of the existing wire that feeds that outlet. Re-route the wires that were going to the outdoor outlet to this new outlet instead. Then plug the appliance module into the new outlet, and plug into that a new wire leading to the existing outdoor outlet. If you are really lucky, there will be enough slack wire so that you can cut the wire going to the outlet and insert the new outlet in-between. In any case, you will need to put a plug on the wire feeding the outdoor outlet. Work safe, don't forget to turn off the breaker first! Good luck.
Jun 17, 2010 | Leviton Weather Resistant Outdoor Switch...
Delux aircon split unit 900btu no display only beeps when power is turned on
MAY HAVE BLOWN FUSE OR BURNT WIRE. MAY ALSO NEED NEW
POWER BOARD. MAY HAVE A SHORT OR GROUND. TURN THE UNIT OFF AND UNPLUG IT FROM THE OUTLET, LET SIT A MIN.
TURN BREAKER OFF A MIN. AND THEN TURN THE BREAKER TO THE UNIT BACK ON...NOW PLUG THE UNIT IN THE OULET AND
TURN IT ON. IF IT WORKS GREAT...IF NOT TRY THE SAME PROCEDURE EXCEPT PLUG THE UNIT INTO A DIFFERENT OUTLET. YOU MAY JUST HAVE A BAD OUTLET. TRY TO USE THE TROUBLESHOOTING MANUAL FOR YOUR UNIT...IF YOU DON'T
HAVE ONE GO TO THE MANUFACTURERS WEB SITE. YOU SHOULD BE ABLE TO GET ONE THERE.
Apr 07, 2010 | Heating & Cooling
Christmas lights not working, please help me solve it
Depending on the type of lights you have, there may be an in line fuse in them, or if one bulb is loose or burned out they all go out. Check along the wiring for a in line fuse holder first. If not it would be a matter of checking all the bulbs.
Oct 22, 2009 | ETC Christmas Lights - 15 Amp Outdoor...
Electric outlet does not work
LETS START HERE , MOST OF THE GFCI BREAKERS WILL SOMETIMES RUN THROUGH THE BATH ROOM OUTLETS AND THEN OUTSIDE IF YOU HAVE A GFCI IN THE BATH OR LAUNDRY OR BASEMENT OR GARAGE MAKE SURE NONE OF THE RESET BUTTONS ARE IN THE TRIP POSITION THE NEC CODE CALLS FOR ALL OF THE LISTED PLACES AS WELL AS CRAWL SPACES AND NEXT TO AC/HEATPUMP TO BE ALL GFCI AND TO SAVE MONEY AND WIRE MOST OF THESE ARE DAISEY CHAINED TOGETHER TO SAVE MONEY SO THEY PUT ONE CLOSE TO THE BREAKER PANEL AND FEED THE REST OFF IT IT WILL BE A GOOD CK I HAVE HAD MANY CALLS FOR THIS THROUGH THE YEARS
Dec 09, 2008 | Rival S12T Electric Skillet
Dryers Logo
231 people viewed this question
Top Dryers Experts
Marvin
Marvin
