Replacement Power Supply Doesn't Work
The front light of my desktop computer blinks red every 2 seconds and the computer won't power up. On the advise of a local computer tech, I replaced the power supply with a new one direct from HP Compaq but the computer still won't power up and I still get the blinking red light. What else could be causing the computer not to work? Please help. Thx.
Lonnie
  • 1 more comment
  • lonrow Dec 15, 2007
    If the computer won't power up, how can a diagnosis of other problems be made? Can the motherboard and ram be tested without the computer powering up?
  • southyr6 Feb 15, 2008
    same problem here. 9 pc's went bad, 6 of one model, 3 of another. the 6 took the new power supplies and worked great, the 3 are trying to sart, but shutting down after a second and then the red light begins to blink.
    HELP!!!!!!!!!!!
  • Anonymous Dec 01, 2008
    none of those... i guess... I have a similar atrix psu and it does that same thing on my high end pc (8800GTS/Q6600) and my low-end(p4/6600GT)
Hi. The first thing you should always check is that all of the wires and connectors are in good shape, making contact where they should, and not shorting out anywhere. I know this sounds simplistic but the way these things are assembled these days with the wires just barely long enough to get to their destination they can pull apart, wear if there is vibration (causing shorts), or even pull or lift solder joints off of the circuit boards. You can test to see if the PSU needs to be connected to the motherboard at the ATX connector by plugging the PSU in and trying to turn it on without being connected to the board. I have found that the PSU generally must be connected to the motherboard in order to work. There was one I had worked on a long time ago that didn't require to be plugged into the motherboard, I think it was a Pentium 2 and it was a very long time ago. Your PSU probably does need to be connected.
If you have a battery backup, Uninterruptable power supply connected, disconnect it. You may well have a bad UPS. Even if you disconnect the UPS and test the voltages it doesn't matter as what you are measuring is not under load. I have seen a bad UPS prevent a computer from working and when it was disconnected the computer was fine. However, if a bad UPS remains connected too long and the computer suffers BSOD or crashes often they can ruin the motherboard.
Well I hope this helps you. It is a decent way to begin to troubleshoot many PSU problems. One other thing, don't forget to use your nose. You can often smell burnt components. If you smell fowl burnt plastickind of oder then try to locate where it is strongest and then look for signs of heat or fire, like blackened circuit board, wire, or components. Good luck. Greg
Posted on Feb 15, 2009
  • 95 Answers
Bad ram, bad motherboard, bad video card, could be any one of a number of things.
Posted on Dec 15, 2007
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
Won't power on
You still have power supply trouble, even after replacement of the board. Recheck the replacement work; could be something wrong there
Jul 19, 2013 | Philips 47PFL7422D/37 Television
My hp compaq doesn't work when i branche the cable of alimentation it signe with red
How many times does the red light come on ? It should blink a number of times, then go off for a little while, and start blinking again. The number of blinks within each cycle will help you find out what is wrong:
Number of 1-second red LED blinks followed by 2-second pause, then repeats:
2-processor thermal protection activated
3-processor not installed
4-power supply failure
5-memory error
6-video error
7-PCA failure (ROM detected failure prior to video)
8-invalid ROM, bootblock recover mode
(http://h18000.www1.hp.com/products/quickspecs/productbulletin.html#spectype=worldwide&type=html&docid=11632)
Jul 07, 2012 | HP Compaq d530 CMT PC Desktop
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
Tv will not come on. Red light blinking on bottom left front. Red light blinks 7 times
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.comj
Nov 01, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
Red light flashing on power button
Sounds like the hard drive has had a failure, you need to get a replacement one, and reinstall it, along with the opperating system, and any other programs that were on the old one.
Feb 14, 2008 | Compaq Presario 5000 PC Desktop
Red light
System does not power on and the LEDs on the front of the computer are not flashing.
System unable to power on.
Press and hold the power button for less than 4 seconds. If the hard drive LED turns green, then:
1.Check that the voltage selector is set to the appropriate voltage.
2.Remove the expansion cards one at a time until the 3.3 V_aux light on the system board turns on.
3.Replace the system board.
OR
Press and hold the power button for less than 4 seconds. If the hard drive LED does not turn on green then:
1.Check that the unit is plugged into a working AC outlet.
2.Open hood and check that the power button harness is properly connected to the system board.
3.Check that both power supply cables are properly connected to the system board.
4.If the 3.3 V_aux light on the system board is on, then replace the power button harness.
5.If the 3.3 V_aux light on the system board is off, then replace the power supply.
6.Replace the system board.
Jan 02, 2008 | HP Compaq Business d530 PC Desktop
HP Compaq d530
it all depends on the number of flashes , pause, repeat.
Since the problem did not indicate any beeps her is the following info
Power LED blinks RED 2 times, one every second, followed by a
2-second pause. = Processor Thermal Protection Activated
3 blinks 1 second apart = Processor not installed (not an indicator for a bad processor).
4 blinks 1 second apart .= Power Failure (power supply is overloaded)
Other possibilities are:
Nov 07, 2007 | HP Compaq Business d530 Ultra-Slim PC...
Computers & Internet Logo
685 people viewed this question
Alun Cox
David Payne
David Payne
