Question about Montgomery Ward (223600UP) Heater
Ward Heater Company M0021
I have a floor heater, that is pretty old, maybe 50 years or so. I can't read the Model Number. The pilot stay lit, but when I adjust the thermostat for heat, nothing happens. The burner doesn't click on. It did work the last time it was cold, about six months ago. The gas company says it may be the blower. Most of the unit is under the house, it is a pretty deep unit.
Thanks for your help.
Reggie
  • Hotshot37 Jan 01, 2008
    I appreciate your comments. I haven't had the chance to try your solution (crawling under the house wasn't my first choice either). I opted to buy an oil heater, temporarily. Thank you for your help.
I have same in old house I live on the last 43 yrs. I replace the thermocouple this part when gets hot makes gas open,bought it in heating and air condition parts here in los angeles, calif cost me about $25 and very easy to replace. You have to crawl under luckily I have plenty space. good luck.
Posted on Dec 04, 2009
    Sergeant:
  • 288 Answers
These old units have a simple gas valve and a separate regulator. Your best bet may be to replace the gas valve to something more modern. Trouble shooting this most likely be a waste of time, as parts probably aren't available, other than the thermostat. by-pass it, (connect the 2 wires together) and see if it comes on. The blower shouldn't stop the burner to come on. Sounds like the gas company doesn't want to crawl under there to light it.
Posted on Dec 26, 2007
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Rheem 50 gal. natural gas water heater mod#21V50-6A followed all instruction and can't get pilot light to stay lit.
The most common reason a pilot light will not stay lit is a bad thermocouple. How old is the water heater? If the pilot light will light, but then go out when you release the safety button, that is a sure sign the thermocouple is bad. You can buy a replacement thermocouple at your local home improvement store. There is a small chance that the control valve has gone bad, but that is highly unlikely.
Feb 23, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Nov 12, 2009 | Heating & Cooling
Water heater will not stay lit even after replacing thermal coupl
The pilot must encompass the thermocouple "bulb" in order for the thermocouple to generate enough current to keep the pilot valve on. You must also hold the red button down for a long enough period to get the thermocouple hot. If the pilot is not large enough, it could be due to a clog in the pilot orifice at the pilot itself. Sometimes a couple of passes over the end of it with fine steel wool is all it takes to clear it.
Hope this helps. Feel free to share what you found. Thanks.
Jul 16, 2009 | Kenmore Dryers
Pilot light on Dyna Glo gas heater won't stay lit
Cleaned pilot light area with an air compressor. Problem solved!
Mar 02, 2009 | Dyna Glo "" Natural Gas Heater Mn200tba
Floor furnace
That is the control for the main gas valve. These old ones have a gas valve separate from the pilot. Also the regulator is separate unit. You have to turn these controls with a long rod, right?
Dec 27, 2007 | Heating & Cooling
Montgomery Ward (223600UP) Heater Logo
594 people viewed this question
Top Montgomery Ward Heating & Cooling Experts
Paul Carew
Paul
Paul
Mack Baxter
Are you a Montgomery Ward Heating and Cooling Expert? Answer questions, earn points and help others
