Fujitsu Siemens SCENIC P300 PC Desktop
Problem for Fujitsu Siemens SCENIC P300 PC Desktop
My Amilo Li1818 has the same blank screen
By george_sipos on Sep 22, 2009
I fell asleep while running on the battery and in the morning everything where dead...propably total dead battery. How can this cause an IC to fail.
There's no BIOS screen, is there any possibility to load new BIOS or run the BIOS from a CD so at least recover data from the HD? It seems to read the CD (at least it tries)...
To bring it to a shop will cost more then the laptop... isn't any other solution?
Best Solution
posted on Oct 15, 2009
Very Helpful)
WadePerkins
Rank: Master
Rating: 83%, 9 votes
As far as the disc drive goes, regardless of if it is connected to a properly running system or not it will start to read a disc. And BIOS is an internal setup menu stored on the motherboard. If it doesn't bring that up, you might have something fried on your motherboard. I can't see how running your battery dead would have caused this though. If you could, would you list any other symptoms? Does the screen light up at all or do you hear the hard drive try to load? I'm sorry I can't be more direct help with fixing it, but it's information I think you might find useful. Best of luck to you, I hope you can get it fixed the cheapest way possible
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 25, 2009
Not Rated)
Turk_97
Rank: Guru
Rating: 89%, 58 votes
Yes, If you have a desktop PC, you can remove your hard drive from your laptop and put it into an external hard drive casing. make sure you get one that can work it. Probably will need a 2.5" hard drive enclosure. Hook it up to your PC and your info should still be on there.
Hope this helps
Was this helpful?
Yes
No
Popular Solutions for Fujitsu Siemens SCENIC P300 PC
Questions and Unsolved Problems for Fujitsu Siemens SCENIC P300 PC
Do you recommend Fujitsu Siemens SCENIC P300 PC Desktop?
Answer
Answer
some of my programs when I choose them comes up cannot find path missing check required libraries to... (More)
Answer
connecting altec lansing speakers. 221 amplified speaker system . trying to connect to my compuer.
Answer
power surge emptied d drive/disc all data gone.computer will not shut down on it's own.
Answer
I made a ecovery disk and it loads and then works, at the botom it says examining 19092 and I'm... (More)
Answer
problem connecting to Gnutella network Bearshare 5.2.5
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu Siemens SCENIC P300 PC...:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
