Question about Nintendo DS Lite Console
Ds green light comes on dim then gets bright then cuts off and nothing!!!!
When i go to turn on my ds the green light comes on dim for a second then gets bright for a second and then just cuts off and nothing happens. can u help me?
  • POTC13 Jan 01, 2008
    same if i play for a long time everything turns off but the green light (red sometimes) stays on  please help
    gamer_freak_93
  • VIIRUS Jan 27, 2008
    dude same thing is happening too me i dont know if its the batterie or what its pissin me off HELP!!
    Sniper:
  • 64 Answers
The light being red only signifies that the battery power is low.
If the light comes on and goes off after a few seconds and the bottom screen flashes the the odds are you need to replace the top screen as the ribbon cable to it has been damaged.
HTH
Posted on Mar 02, 2008
There is no power and it will not charge
Posted on Dec 15, 2007
Ds light green,dim green, amber then off when power is turned on
Sounds like you need to send it in for repair. I had sent my console to VideoGame911.com and they repaired mine at a great cost and got it back at the end of the week. Give them a try, they are cheaper than a manufacturer. Good luck!
May 04, 2013 | Nintendo DS Lite
I turn on my ds green light comes on bottom screen flashes then turns off
    • 1 Turn off the Nintendo DS, and place it on the charger. Leave the device for 45 minutes to allow it to gain a full charge, and then power it back on. Weak Nintendo ds lite batteries may cause screen flicker.
    • 2 Turn off the DS, and remove all game cartridges. Turn the system back on to launch the main menu.
    • 3 Click the small sun icon to open the brightness menu. Adjust the brightness level using your stylus. Turn it up to max to improve back lighting.
    • 4 Check that the Nintendo DS is open and in the locked position. It must be open to its default position to operate properly.
Apr 15, 2012 | Nintendo DS Console
Cannot power up the DS Nintendo. The light will come on for a split second and than go off again.
I bet you have replaced a screen or opened the DS. The ribbon cables for the screens have to be securely located and ALL THE WAY into the holders otherwise the DS lights to show an error. the ribbon cable error looks like this when you power on--- Dim green for a second then bright pulse green then off.
If this is happening its a cable error RE-SEAT even if you think they are. If you get that error it is deffinately cable.
Jun 21, 2010 | Nintendo DS Lite Console
Nintendo DS Lite, Dim Green Light, Brigher Green Light then off
If the green light reacts as you state then the chances are the fuses are fine.
Again, with the reaction of the green light being as you stated i'm going to assume you have a problem with one of your screens, tell me... when the green light comes on does one of the screens flash? If it does then we have found the answer...
The screen that doesnt flash is the one with the problem, you can try taking the DS lite apart and re-connecting the screens ribon to see if that sorts it, if it doesnt then im afraid you will have to buy a new screen. These can befound on ebay for a reasonable price.
I have written some guides on how to change your screens and how to disassemble the DS lite, these will guide youthrough the processes you need to take. These can be found by clicking on my name and then scrolling down to "tips and tricks", press the "view all" to see all of them and find what you need.
I hope this helps.
Regards,
SOD69
Jan 03, 2010 | Nintendo DS Lite
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
The DS Green Light Cuts On But Shuts off after a few seconds
I dont now about the sound but for the battery is that the ds charge battery is over! if you see backwards you will need to open it and buy a new battery thats all!!!!!! I try it it works
Jun 06, 2009 | Nintendo DS Lite Console
RE:nintendo DS lite power light comes on but both screens stay dark?solution
Wotterz.
This is a problem with the cpu on the systemboard. I've seen this problem many times if the DS Lite is felt to the ground. The contacts of the cpu are very fragile. The DS Lite turns on, green led available, even charche is working bot nothing else. Repair of this problem is almost impossible. The only thing you can do is send it to Nintendo.
You can test if it is the cpu by removing the bottom of the DS Lite and put the battery on te contacts.
Press firmly on slot 1 (the aluminium cover) and turn the DS Lite on. If you got a picture on the screens then you know it for sure. The cpu is located under slot 1 and by pressing on de top of the slot you are pressing possible loose contacts back on de systemboard.
If it is not working then the cpu is to musch damaged.
Let us know what you've found with this solution.
Sep 20, 2008 | Nintendo DS Lite Console
Nintendo DS lite power light comes on but both screens stay dark?
When you boot the Nintendo DS you can change the illumination settings in the main menu.
One the main menu, you will find a sunny symbol in the lower left corner of the screen. Click on that and you should be able to change the level of illumination. If you are also wondering if you can change the brightness during game play, you can't. Games such as Mario 64 DS come with support for brightness change but otherwise you have to do it before game play.
Nintendo DS Lite Console Logo
451 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
