i put in my code to run streaming for the ps3 and i get an error message saying that my internet...
(More)
I PUT IN MY CODE TO RUN STREAMING FOR THE PS3 AND I GET AN ERROR MESSAGE SAYING THAT MY INTERNET EXPLORER CANNOT DISPLAY THE WEBPAGE. I THEN DIAGNOSE CONNECTION PROBLEM AND IT SAYS CHECK FIREWALL SETTINGS FOR HTTP port(80),HTTPS port(443), AND FTP port(21). help
I have a Nokia IP380 that I am trying to reimage a hard drive for. Another IP380 that is full...
(More)
I have a Nokia IP380 that I am trying to reimage a hard drive for. Another IP380 that is full functional boots up IPSO just fine. So far I have tried using Acronis and PING to image them and neither has worked. They image the data fine and even pull up the bootloader on the new image but wil basically freeze when I load it up. I tried swapping the drives and it worked so I know the rest of the hardware checks out but whenever I connect a serial cable and term in on the imaged machine it just freezes at the boot loader.
Hi, My IP380 is installed with Checkpoint firewall software. The equipment is installed in a LAN...
(More)
Hi, My IP380 is installed with Checkpoint firewall software. The equipment is installed in a LAN environment, separating the client sector and the server. Problem: At times, client login to the network will fail and so far the only resolution found was to bypass or reload the image. However, when comes to IP350 or IP390, we don't face such problem. Need assistance..
Does anyone have the proceedures to load a harddrive from scratch on a Nokia IP380? I have the...
(More)
Does anyone have the proceedures to load a harddrive from scratch on a Nokia IP380? I have the procedures for the IP530 but they are not usable on on an IP380.
