Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Hoover vacuum handle attaching screws
Vacuum arrived without any screws to attach handle to the unit.  Are the screws a fine or coarse thread?  I cqn subsitute something from my garage supply of spare screws/bolts I assume.
    President:
  • 1,673 Answers
They are just a coarse thread(very coarse) about 3/4 in long, phillips head.
Posted on Jan 06, 2008
Hoover quick & lite carpet cleaner stopped spraying solution. What can it be
Hey, this is Jeremy with Crucial Vacuum,
Sorry to hear you are having difficulties with you Hoover Quick & Lite. There are a few different things we can try to fix your hoover and get you cleaning again.
1. The sprayers may be clogged. Over time they will get clogged with soap and mineral deposits. This is a natural thing to happen, so don't fret. Fill you tank with a solution of half warm water and half vinegar. Let the mixture sit in the tank while the vacuum is running for awhile and then try to spray solution. This should loosen up anything clogging the sprayers and allow for a consistent flow of liquid.
2. Your handle may mot be attached properly. To fix this remove the 2 screws at the base of the handle on the back of the vacuum. Check the control arm inside. Make sure they are aligned properly. Below I have attached a video showing you how exactly they should look.
https://www.youtube.com/watch?v=UXwLERxWjGU
3. The clean water solution tank is not installed correctly. Make sure the tank is attached firmly to the gasketets and nothing is out of place. Below i have attached a link to your vacuums manual which has diagrams for exactly how the tank and unit should fit together.
http://hoover.com/file/958/
You can purchase replacement parts for Hoover direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/hoover.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jul 12, 2015 | Hoover Vacuums
How do i fix my hoover windtunnel if self propel is stuck on ?
There is a cable that goes from the handle to the base, the cable or the plastic piece it attaches to at the base of the vacuum may me broken.
Jan 31, 2015 | Hoover Vacuums
What size screws are needed for the bottom plate of a Hoover U5061-900, the screw part number is 012-21447121
Any coarse thread screw about 1/2" long will work. There's no real "threads" inside, its just cut when they put the screws in at the factory.
Apr 01, 2013 | Hoover Elite U5061-900 Bagged Upright...
Just replaced the belts on my Hoover Windtunnel II self-propelled vacuum. The brushes are now turning ok, but the self propelled feature is not working. Squeals when when you lock it in the upright...
Check the plastic part, which the the self propelled cable is attached to. (release the handle, tilt it back. You should be able to see the cable attached by a screw to a black plastic arm.) It is either broken or the cable is lose.
Nov 14, 2010 | Hoover U6630-900 WindTunnel Bagless...
Hoover Z700 the mechanism that closes off the vacuum behind the agitator brush will not open.
You will need to take the top off. It is easy: turn the vacuum over and look at the bottom (where you can see the beater bar). There are some deep screw "wells"; these are the screws you need to take out plus the 4 silver looking screws that hold the beater bar plate in place. When you bet those out, there there will be a "notch" at the front, behind the LED light you will have to disengage. Turn the vacuum back over and take the gray top off. You should be able to see the engagement latch that is attached to the handle. This is what opens and allows the flap to shut. It has a spring attached that may have come loose. Good luck.
Apr 15, 2009 | Hoover U9145-900 Z Bagless Upright Vacuum
Hoover Self-Propelled WindTunnel U6436-900 cable problem
The flat belt should be changed if it has been longer than 9-12 months. Next I would remove the upper handle to inspect the top section of the control cable, sometimes it fray's and has a sponge feel (no positive control) to self propel. To set this adjustment, it is best to do withthe hood off of the lower section. I would also look at the cable jacket in the foot to make sure it is under the metal clamp. It must be under the clamp to work properly. To get it under the clamp loosen one hold down screw at the top and one in the back of the vacuum, remove clamp screws and put jacket into position and then secure all screws. Now set the adjustment, Install upper handle and set self propel to off. loosen cable from arm in foot with torx screw. manually move arm until the clutch is off both drive pads. This is a visual adjustment. then secure and reassemble vacuum.
Feb 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Model number U5763900 Serial Number 090400013588 Handle broke off just above the four screws that attach it ti the boby of the vac. Hoover does not list parts for models that are more than two years old....
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=658103
Generic problem for all Vacuums
Posted by rlholif on Jun 09, 2008
Model number U5763-900 Serial Number 090400013588
Handle broke off just above the four screws that attach it to the body of the vac. Hoover does not list parts for models that are more than two years old. The vac operates perfectly but without a handle my wife cannot use it, where can I find a part replacement. Easy to remove four screws and replace. Don’t want to drive 100 or more miles to find an authorized repair shop. Oh yes, this is a Hoover Preferred Wind Tunnel Bagless
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You have all the information needed but I would contact your local vacuum cleaner dealer and they may have a good used one or they may stock a new handle for your you or they can ship you one If you live too far from a factory authorized dealer. The vac shop that I worked in always had good used parts for ½ the price and it worked just fine – the only difference was the color and for the handle that would not make a difference in the performance and your wife could use the vacuum again. Also Hoover can ship the part to you providing they have it in stock. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Vacuums
Replace interior hose for cleaning attachment for Hoover Steam Vac Agility
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=632107
Replace interior hose for cleaning attachment for...
Posted by castcomm on May 29, 2008
How do you dismantle handle to replace aforementioned hose?
Swing arm on unit goes all the way to the floor. Is this normal? Is there a "stop" broken that caused the hose to stretch, and ultimately break?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There are handle screws that you can get into the handle and then you can back track the replace the interior hose for the cleaning attachment. There should not be a stop that caused the hose to stretch ad break. The hoses after a while do get old crack and break due from normal use or if the bend @ sharp angles, this is common among all vinyl vacuum cleaner hoses. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Water flow issue
The attachment hose is likely coaxial - meaning that it is a vacuum hose with the water supply line running through it. It is likely that the vacuum (outer) hosing is damaged. The attachment will still spray, but will not vacuum. if you lay the handle section all the way down and look inside the unit, you will probably find the problem.
Aug 23, 2007 | Hoover F7431-900 SteamVac Vacuum
Self Propel doesn't work! where does the cable attach from handle? How do u do it?
if you haven't already gotten this fixed, simply remove the two screws on the bottom of the handle. Inside is the cable; please make sure to unplug your vaccum first.
Sep 05, 2006 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
64 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
