Question about Maytag HYG2460AWW Gas Dryer
Kenmore Dryer I have a kenmore dryer, can you tell me where the motor is located? It is making a buzzing sound but will not start. Sometimes it will start but once it heats up, it stops running.
    Problem Solver:
  • 8 Answers
Unplug the dryer turn off the gas valve and remove the rear panel the motor is located below the drum
Posted on Dec 15, 2007
Start switch buzzes and won't start the dryer
I had possibly a similar problem with a Kenmore 90 electric dryer. Sometimes pushing the start button would just make a buzzing sound, but the drum would not turn.
I ended up replacing the motor and so far it seems to start up smoother and quicker. In the process of taking it apart, there was a surprising amount of lint piled up in front of the blower intake. This is after the lint screen and not really possible to get to without taking off the lower front panel and then removing the duct to the blower. Perhaps it was dragging on the blower and causing the motor to overheat. Worth looking at first, perhaps.
Apr 01, 2014 | Kenmore 73952 Gas Dryer
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Oct 02, 2011 | Kenmore 63942 Dryer
Kenmore electric dryer series 70 makes loud buzzing noice
Sounds like you have a motor problem draging and it can't get started I just replaced one same problem.
Apr 24, 2010 | Kenmore 63942 Dryer
My kenmore dryer push start button is not engages the unit but the button will not stay on! Any advise
if the start button is making a buzz sound and not kicking the dryer motor in then the motor is bad-mike
Mar 01, 2010 | Kenmore Dryers
Dryer doesn't always start, and doesn't keep running
your have a dieing dryer motor,weak weak to turn the drum anymore,the model number is inside the dryer door if you want to try and find one cheap on ebay-mike
Feb 23, 2010 | Kenmore Dryers
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Kenmore gas dryer buzzes but does not run
sounds like the start windings in the motor have gone bad. The only way to fix this is to replace the motor.
Feb 04, 2009 | Kenmore 73932 Gas Dryer
MY KENMORE MODEL 110.76722694
You have a bad motor. You can remove and verify probably bad bearings and burnt start winding.
May 16, 2007 | Kenmore 74992 Gas Dryer
Maytag HYG2460AWW Gas Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
