Question about Fellowes DM8C Cross-Cut Shredder
Does not feed paper
The motor runs and will not except a piece of paper
  • Anonymous Apr 03, 2008
    motor starts , but will not continuing running there seems to be some residue from previous shredding in the slot. thanks for any suggestions
How did you take the top off? I have the same problem.
Joel
Posted on Apr 01, 2008
  • joey5 Apr 01, 2008
    I have the same problem. Can someone tell me how to get the cover off? I have taken out all the screwss but it will not come off. Any help would be great!
    Joel
Had the same problem. The gears inside the shredder have worn out. I overfed the shredder with too much paper and caused the nylon gears to slip and strip away the teeth. Now the motor won't engage the cutters when you attempt to feed the machine. If your handy you can take it apart, find the gears, contact the manufacture and have them send you out a new set for that model. If not, then you will need to buy a new shredder. In my case, they sent out new gears, it took forever to receive, and when I did get them one gear was the wrong size. I had them send out a new one, and again after weeks it was still the wrong gear, even after sending them pictures! I am now buying a new shredder, and I am spending a bit more to get a more robust machine that can handle more of the workload I need.
Posted on Dec 15, 2007
My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
Mar 27, 2015 | Shredder Office Equipment & Supplies
Samsung printer clx-3185 paper jam under rollers
You should be able to turn the rollers manually and take the pieces out, just make sure to have the unit unplugged first
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Jul 14, 2014 | Electronics - Others
Had small piece of paper stuck, removed paper but error code still there. Motor by paper when turning back on just runs and runs until I unplug. Error code still there.
look like still there is something stuck or paper sensor has malfunctioned , try using blower to clean it , or take it to authorised service centre
Mar 12, 2014 | Computers & Internet
My shredder quit working.
First thing you have to do is clear all jammed paper. Second..try running machine; if the motor runs and the blades turn put some shredder oil into the cutting blades as lubricant. If the motor wont run you have probably blown the pcb because of too much paper... to get replacement part call Royal at 1-800-524-0799.
Jul 15, 2010 | Royal Office Equipment & Supplies
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
Kenmore top load hqavy duty 80 series model 82980120 - how does one get to the drive belt. Washer motor hums but no action any cycle.
Your complete model number including the first 3 numbers , is needed to help you get to the coupling . The coupling , is the piece ( pt # 285753 ) which connects the motor to the transmission . When this piece breaks , the motor will run , but no machine action , except for water drain . Even spin , will not work , yet , you will hear the motor running .
Oct 11, 2009 | Kenmore 24032\24036 Top Load Washer
There is paper stuck in the shredder how do I get it out. I have tried the reverse and forward several times.
IF YOU GET A PIECE OF THICK PAPER OR AN ENVELOPE AND FEDD THAT THROUGH IT SHOULD CLEAR IT FOR YOU YOU COULD OPEN THE DOOR AND FEED THE PAPER UP FROM THE BOTTOM BY CHEATING THE DOOOR SWITCH BY PUTTING A PIECE OF PAPER IN THE SLOT FOR THE ACTUATOR THAT WILL LET THE MOTOR RUN FOR YOU...hOPE THIS HELPS a
Jul 30, 2009 | Royal VF1012mx Shredder
Paper Shredder blades do not turn, even though motor is running
yes, it's the plastic gear that's shredded in this shredder. the drive gear on the motor is metal, as are the gears attached to blades. between is a single plastic gear which is chewed up the instant resistance is great enough. fabulous engineering. not a difficult fix, but where does one find the replacement part?
Jun 08, 2008 | Office Equipment & Supplies
Paper feed
What the hell, I have a mid-term that is due and I need this thing to work, What a piece of ****!
Jan 10, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
My techko SH 3112Fa won't turn off
I had the same problem with my Shredded. In the centre of the paper feed slot is a little sensor that detects when you put paper in, it breaks some sort of light beam that is connected to the motor circuit.
Over time paper dust gathers on this sensor, covering it completely and fooling the machine to think that there is ALWAYS a piece of paper being fed into the shredder, the result being that the motor just runs continuously.
Clear the dust from this sensor and you'll fix this particular problem - a toothbrush worked great for me - don't use it to clean your teeth afterwards :-)
FIXYA!!!
Oct 11, 2007 | Office Equipment & Supplies
Fellowes DM8C Cross-Cut Shredder Logo
179 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
