Question about 3Com OfficeConnect TP800 8-Port Ethernet Hub (3c16722n)
Network Hubs I want to see a video demo on how to connect network hubs and the host to other pc from the begining
  • tntang Jan 10, 2008
    can not get internet on 2nd computer
  • Anonymous May 04, 2008
    webcamara
  • 51 Answers
Please log on to www.youtube.com for your clarification there you can get an clear idiea about everything..
Posted on Jan 05, 2008
How do I configure the OfficeConnect TP800
There is nothing to configure. Hubs simply spit a network connections almost like a TV cable splitter divides cable for separate rooms.
Hubs require a router that manages the network by providing IP and other network management tools.
Dec 10, 2012 | 3Com OfficeConnect TP800 Networking Hub
Conflict message
if u have 2 PCs connected to the hub/router then you must specify the IP address in Network Connection wizard..../ LAN properties / TCP-IP setting Tab......set each PC different....IP address
say like this.....
192.168.1.3 for 1st PC
192.168.1.5 for 2nd PC
the rest of the settings is based on you internet service provider
this will work....
Jul 15, 2010 | NetGear EN104 Networking Hub
Why only 254 computers are connected in one network for ex:172.16.100.1 to 172.16.100.254
If we use class c network (192.168.x.x) we can connect devices up to 254 because in class c network first three are network positions. last one is host position. (network posotions 192.168.x host postion is x last one) In class B network mean 172.16.100 we can connect more than 254 because in this network ips are 1-254 after 254 hundred we can change to 101.
Note: In class B network 2 network and 2 host positions. network positions are fixed. Host positions are changeable. so we can change. like that class a one network position and 3 host positions. (ex: 10.0.0.0 in that 10 is fixed. remaining we can give as we like) but we cannot give 256 ip address to any client. because that calculations support up to 254 only
Jun 20, 2010 | Network Computing Devices (NSH800S/A)...
How do i access it from my laotop to make changes
The hub you've listed here cannot be managed. Hubs are non-intelligent devices. What changes did you want to make to a 4 port hub? Hubs are just used to physically connect network devices.
Mar 04, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
I need to design a net work for a company with 4 subnets and each subnet work have about 30 hosts. I've chosen a star topology for each sub network. what is the best centralized device should I...
You are going to want to use a switch. the reason you will want to use the switch is because of the different subnets that you will have and the hosts that you are going to have. You will have faster and more reliable connection. With a Router or a HUB the connection will get over worked and you will see the time it takes to do something is that much longer. Always use switches with more then 15 hosts
Jan 02, 2010 | Cisco (NO RETURN) CAT3750 24 10/100 POE +...
Intermec 9180 network controller RF suystem not communicating wit
The first thing I would suggest that you should do is that, try connecting to another host, or a laptop.
If it connects, then you might need to just change the network adapter of the host that is not connecting.
But if it still doesn't connect nor show any light, then try to check your network cable if it is faulty. You can just try connecting with another cable that you are sure that is working.
Kindly keep me posted about the problem.
Hope it helps.
Good luck.
Nov 18, 2009 | Computers & Internet
How to use cross cable and straight cables in network
ok, i think what you mean is this.  Crossover cable is for connecting 2 computers together without the need for a router.  also called pc-to-pc.  Straight cables need the use of a router or hub to connect 2 computers together.  Hope this helps, if not let me know more info.
Mar 06, 2009 | Southwestern Bell (S60802)
Connecting campus wide networking to hub
Check the following:
Hardware First: Is Vista confirming LAN connection onn that PC, or is it showing disconnected cable?
Is the connection properties showing at least 100Mbps?
Are the RJ45 terminals okay?
Is the driver for the network card recognized by Vista and loaded?
If that is fine, then check the following in the network properties:
1. The IP address you are using
2. The gateway address: it must be the same as the gateway address in the other PCs accessing internet. Run and check
3. The Subnet mask. Use 255.255.255.0
4. HAve you Setup the Nework using the Setup Wizard, including Access INTERNET THROUGH A HUB THROUGH ANOTHER COMPUTER ON MY NETWORK?
Check those things and let us know. Ask for help from your network administrator about correct IP addresses on that LAN
Feb 26, 2008 | Compex MicroHub TP1008C Networking Hub
3 com hub tp4 home network setup failure
There are several possible problems here, and more information is needed to identify which one is causing trouble. First, are you using a high speed dsl or cable internet connection? ...or is your Internet connection a dial-up phone line? This will have a significant effect on how your cables should be connected between the hub and the computers. Windows typically defaults to a 169... address when it is not properly connected to a shared network connection.
Jan 08, 2008 | 3Com HomeConnect (3C19261) 5x10/100 Mbps...
3Com OfficeConnect TP800 8-Port Ethernet Hub (3c16722n) Logo
114 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
john smith
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
