Question about Whirlpool GEW9250 Electric Dryer
The panel light says control locked
The dryer will not turn on when is just worked. The control locked light is on. Tried unpugging for 30 minutes
  • 170 Answers
Hey ,check this link and input your model # this will give you the service manual on your unit
http://servicematters.com/docs/wiring/wiring_main.htm
Posted on Dec 15, 2007
  • bharath m
    bharath m Dec 17, 2007
    Someone in your home has activated the child safety switch. On the lower right hand side of the control panel, hold the bottom button in for 3 seconds until the light goes out.(safety control lock switch)
    Sergeant:
    Champion:
  • 298 Answers
Some dyers have a cool down safety feature
could be activated or could be a broken belt
check for a broken belt also
  • Eugene Merritt Dec 22, 2007
    If the control lock sw was inadvertenly locked it can
    be unlocked by:
    To unlock:
    Press and hold the END OF CYCLE SIGNAL button for 3 seconds
    to turn this feature off.
    NOTE: When the dryer is running and Control Locked is on, the
    dryer can be stopped by pressing the Pause/Cancel button, but
    can’t be restarted until the control is unlocked.
Samsung j1455av front loader washing machine lcd control panel frozen
when you disconnect from power you should wait about 5 minutes prior to reconnecting. Also check the panel to be sure you didn't place it into a "lock" mode. This can be corrected simply pressing the correct selection(s) to "unlock" the control panel.
Make sure the dispenser drawer is fully closed as some units prevent operation until properly sealed to prevent water leakage.
Nov 22, 2017 | Samsung Washing Machines
How to unlock controled lock
You can try a hard reset.
Turn the machine off if you can
Unplug it from the wall outlet
Leave it for about a minute
Plug it back in.
Always use caution when working around electricity and a washing machine
Are there any lights showing on your machine? What is the make and model of our washer?
Dec 31, 2010 | Whirlpool Washing Machines
There is a button on the control panel with a marking under it that says "Press and hold for 3 seconds to lock/unlock control". Look for the said button then press and hold it for 3 seconds or until the control lock light turns off. The button is usually the Auto Dry Level button for Kenmore Elite dryers and the Drain/Spin button for Kenmore Elite Washer. Whirlpool Duet Washers and Dryers use the End of Cycle Button to lock and unlock the control.
Sometimes the problem is due to an electronic glitch and unplugging the machine for at least 30 minutes may solve the problem. But if the control cannot be unlocked by pressing and holding the button specified above or by unplugging the machine, the control panel electronics may need to be replaced.
Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The control lock button is light up and the washer won't work.
Sometimes the problem is due to electronic glitch and unplugging the machine for at least 30 minutes may solve the problem. But if the control cannot be unlocked by pressing and holding the button specified above or by unplugging the machine, the control panel electronics may need to be replaced.
Dec 23, 2010 | Whirlpool Washing Machines
How do i get the control lock button to turn off?
Dec 21, 2010 | Kenmore Elite HE4 Electric Dryer
Control locked on my Whirlpool Duet GGW9250PW0.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
(Tip Courtesy JSRock)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 22, 2009 | Whirlpool GEW9250 Electric Dryer
Control Panel Kenmor Elite HE4
that sounds weird to have all those lights on...
first thing is to try and remove the "lock"light...
push and hold the button, for 5 seconds, below the "lock" light,
that should get the control back to normal operation. then if you still cant get the unit to turn on, try to unplug the dryer for a few minutes.
if you still cant get it to turn back on, call sears "customer service" and complain since your machine should not have failed at this early in its life.
Sep 15, 2009 | Kenmore Elite HE4 Electric Dryer
Control panel locked
At the far right buttons on control panel, the very bottom far right button says control lock. hold in for 5-10 secs and the control lock will turn off.
Aug 24, 2008 | Whirlpool GEW9250 Electric Dryer
Control panel locked light is on
ck for a button with hold to lock under it hold button 3-5 sec
Jul 02, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Front Load Duet Dryer
Elsewhere on this forum a fix was given that is rather easy. Someone in your home has activated the child safety switch. On the lower right hand side of the control panel, hold the bottom button in for 3 seconds until the light goes out.(safety control lock switch)
Nov 11, 2007 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
43 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
