I mistakenly deleted the sond driver...... And unfortunaely i don't have the DVD with me . On net from where i can get the driver. Plus my window is installed in Russian language...... is there any way i can change the language withour re-installing the window.... as I don't have the excess to external CD/DVD rom yet.
You can download the drivers from ASUS site. Make select your model laptop, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Click on this link :- http://usa.asus.com/index.aspx
If you need to type in a foreign language on your computer, you can do so by changing the input language (i.e. keyboard language). Just follow the instructions below Windows VistaWindows XP
Instructions for Windows Vista
Click Start and then Control Panel
In Control Panel, if you are in Classic View, click on Control Panel Home (top left corner)
Open Clock, Language, and Region
Click on Regional and Language Options.
Click the Keyboards and Languages tab and then click Change keyboards.
Under Installed services, click Add.
In the Add Input Language dialog box, select the keyboard layout you would like to add from the list available and click OK.
The keyboard layout you added will be included in the list. To set the new layout as your default, select it from the list. Click OK to save your changes
You can switch between different input languages (= keyboard languages) by clicking on the Language Bar button or by pressing the Alt + Shift keys
Instructions for Windows XP
In Control Panel, if you are in Category View, click on Switch to Classic View (top left corner)
Open Regional and Language Options.
Click on the Languages tab.
Under Text services and input languages, click on the Details button.
In the Add Input Language dialog box, choose the input language and keyboard layout or Input Method Editor (IME) you want to add.
Click OK twice. You should now see a language indicator in the System Tray (located at bottom right hand corner of the desktop by default). You can switch between different input languages (= keyboard languages) by pressing the Alt + Shift keys
If a language does not appear in the Input language list, the fonts for that language might not be installed. If that is the case, follow the instructions below.
Add language support
Open Regional and Language Options in Control Panel.
Under Supplemental language support, select the check box beside the applicable language collection
Click OK or Apply. You will prompted to insert the Windows CD-ROM or point to a network location where the files are located. After the files are installed, you must restart your computer.
Hi you can change the language from russian to english ..
Just fallow these steps
1. Open Regional and Language Options by clicking the Start button ,
clicking Control Panel, clicking Clock, Language, and Region, and then
clicking Regional and Language Options (Its a Globe ICON).
2. Click the Keyboards and Languages tab.
3. Under Display language, choose a language from the list, and then click OK.
If you don't see the language you want on the list of display
languages, the other answerers are right: you'll need to install
additional language files first.
I have an ASUS F5RL-X3 I can not access the recovery console using F9, nor can I repair it using OEM...
(More)
I have an ASUS F5RL-X3 I can not access the recovery console using F9, nor can I repair it using OEM WIN XP Pro disk. I have changed boot priority so that CD is first device however it goes to HDD. I just want to get it started in recovery or DOS so tat I can manually fix registry and run chkdsk /p/r. F9 does not work!
wont allow facebbook access , have set all the interbet settings to factory settings, cant do a...
(More)
wont allow facebbook access , have set all the interbet settings to factory settings, cant do a restore as not enough memory, taken of AVG as was told thats the porb, trying to sort out a friends one and its just not having it
I have an asus eepc and a few months back I installed Windowz xp in it. However, I cannot connect to...
(More)
I have an asus eepc and a few months back I installed Windowz xp in it. However, I cannot connect to the internet. How can I fix this problem?
