Question about Microwave Ovens
Microwave oven problem
It will start when the door is opened
  • jacklu2 Nov 20, 2008
    MH3184
    A little wiggle of the door starts the unit. Pressing CANCEL does NOT stop it. You have to open the door to stop it.
  • 3 Answers
Sounds like door locking mechanism or door switches are inoperable, had same issue, turned out to be broken plastic door latch. Replacement part on Repairclinic.com for less than $10.
Posted on May 28, 2008
KitchenAid microwave oven model # KMHS120ESS-0 When you open the door the light doesn't always come on and you can't get the microwave oven to start because it thinks the door is open.
You either have an intermittent or defective door switch, or the latch assembly is not activating the switches properly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Nov 29, 2016 | KitchenAid Microwave Ovens
When I open the Panasonic microwave oven door by pushing in the door opening button, the oven starts immediately
There is evidently a fault with the door interlock switches. Don't use it as the oven may avtually be emitting microwaves with the door open.
Get a service tech to quote you for repair as it may be more economical to buy a new one, when you will have a warranty.
Do not try to repair it yourself unless you have detailed knowledge as there are components inside which can deliver a lethal shock even when the oven is not plugged in.
Sep 30, 2016 | Panasonic Microwave Ovens
When press START microwave timer starts but will not heat?
Your door safety interlock switches are the primary candidate for this problem. The oven thinks the door is open because one or both of the switches are faulty or out of alignment. When the door is open, NO HEAT. Check em out.
Jun 09, 2011 | General Electric Microwave Oven
I have a GE JE1540 Microwave Oven and worked good for more than 10 years. Recently it got a problem. When the microwave oven stop and I try to open the door to move out the thing from microwave oven, it...
In the cases I've seen, the fan starts operating and sounds like the oven is cooking. This is usually caused by one or more of the interlock switches being out of adjustment.
Jun 20, 2010 | GE JE1540 Microwave Oven
My JE 1860 microwave starts working when I open the door.
It sounds like the door switch is bad. It may be that the switch is shorted inside. I would think it may really run with the door open, and microwave you.
Mar 06, 2010 | GE JE1860 Microwave Oven
I have a 10 year old MH7130XE Whirlpool microwave oven. The oven and key pad both work, and the oven heats just fine. The problem is the oven begins running as soon as you open the door...without pushing...
I'm assuming you mis-typed and meant the oven begins running when you SHUT the door and stops when you OPEN the door. Please tell me this is what you meant! If the microwave oven runs with the door open, UPLUG IT IMMEDIATELY AND DO NOT USE IT!!!
If the oven begins running without pushing the start button then the controller is bad or the Start button is worn out and making contact without pushing it. (Most likely it is your controller.) Generally, it is not worth the cost to replace the controller on a 10 year old microwave. Probably time for a new one.
But if you want, you can call Whirlpool and see what they suggest at 800-253-1301.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Whirlpool MH7130XE Microwave Oven
MIcrowave runs with the door open also
your door switch is mis-adjusted,furthermore the other safety switch on the door should have blown the power fuse in the unit,because by design for safety it produces a short circuit if door opens under operation,so if door was taken off and replaced it was not adjusted properly
Aug 15, 2009 | Sanyo EM-P790 Microwave Oven
Microwave Ovens Logo
88 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
