Question about Nintendo DS Console
Can DS game cartridges be cleaned/fixed?
We have several games that were not working on a DS. Thought it was the DS and purchased a new DS. Games still don't work. Is there a way to test/fix the cartridge?
1. Use a q-tip to gently rub the gold-colored electrical contacts on the cartridge. You can use a bit of hydrogen peroxide or cleaning alcohol, but be sure to let it dry completely (12-24 hours) before putting it back in the DS.
2. Use a pencil eraser to gently clean the electrical contacts. No need for liquid, but be sure to gently remove any residue from the eraser before you plug in the cartridge.
3. Buy and use some electrical contact cleaner on the contacts. This is available in places like Radio Shack and usually comes in a small aerosol bottle with a little brush attached. Again, let it dry before inserting it in the DS.
Posted on Dec 19, 2007
2 Suggested Answers
  • 60 Answers
SOURCE: Nintendo DS Games
you either have bad games or problems with the ds had same problem mine was a bad game...
Posted on Jan 28, 2009
Tip
DS Lite Slot -1, games cartridge not reading games repair / resolution.
Has your slot -1 games cartridge reader stopped working? Is it being temperamental with your cartridges? Here are a few tips to get your DS lite back to full working order.
1) First try giving the games cartridges metal contacts a clean, ideally with a cotton bud and white spirit (if you don't have white spirit try avoiding anything soapy, if you can try to stick to an alcohol based solvant such as nail polish remover).
2) If that doesn't work you can try cleaning the cartridge socket (slot1), you can buy proper cleaning cartridges for the DS lite, or, if your feeling brave you can get a jaye cloth, dampen it with an alcohol based solution (same as what is used to clean the cartridge) make sure it is well wrung out so that the cloth is only slightly damp and thinly wrap it around a rigid ruler, which can then be gently placed into the slot to give it a bit of a clean.
3) If both of those fail you may find that some of the pins within slot1 are bent/snapped and so this will need to be fixed, If under warranty i'd suggest taking them in to get looked at. If they are not and you feel brave you can set about fixing it yourself, take the DS lite apart and have a look at the pins on the slot1 socket, if they are damaged you can buy a replacement socket on ebay, but be warned it is a tricky job to solder a new one on.
To solder the replacement slot -1 on firstly you will need to remove the old one, take care not to damage the pcb tracks when doing this as it will cause the replacemet process to be far more difficult and a purchase of a track repair fluid may be needed. Your best option is to de-solder it buy removing the exisiting solder to free it from the motherboard. Once you have done this you need to put the new one on, take great care not to fuse any of the pin connections together with the solder as this will cause the DS great problems and break it. Re assemble the DS lite and give it a try.
If you need help with taking the DS lite apart please refer to my other tips and tricks posted on here.
Just so you know I take no responsability for any damage that may occur whilst following these tips.
Regards,
SOD69
on Feb 08, 2010 | Nintendo DS Lite
Ds keeps coming up with "An error has occured. PRess and hold the POWER button to turn the system off" when I try to play Super Mario game. All other games are fine.
Since it is only causing a problem for this game, the problem is likely with the game and not with the DS itself.
Is this a newly purchased game? Sometimes black market games will show this problem.
If it is not new, then check the bottom parts of the game cartridge to see if there is some damage or dirt. These can make the game unreadable. If it's only fingerprints, you may be able to clean it, but otherwise you'll have to purchase a new cartridge.
Best of luck.
Jul 21, 2010 | Nintendo DSi Black Console
I have 2 DS lites. There are a couple of games,
Could be one of a few possibilities, First try giving the games cartridges metal contacts a clean ideally with a cotton bud and white spirit (if you don't have white spirit try avoiding anything soapy, try and stick to an alcohol based solvant such as nail polish remover).
If that doesn't work you can try cleaning the cartridge socket (slot1), you can buy proper cleaning cartridges for the DS lite, or, if your feeling brave you can get a jaye cloth, dampen it with an alcohol based solution (same as what is used to clean the cartridge) and thinly wrap it around a rigid ruler, which can then be gently placed into the slot to give it a bit of a clean.
If you need any further help or advice feel free to message me and I will do my best to help you. (If it comes down to it, if you are local to Bedfordshire, UK I can always take a look at it for you).
Regards,
SOD69
Dec 30, 2009 | Nintendo DS Lite Console
Nintendo DS Games
Jan 26, 2009 | Nintendo DS Lite Console
Cant play games on nintendo ds lite
I can tell you.You might have to clean the back metal strips on your Ds game or game Pak.Also the game pak's internal battery has runned dry.Use a cutip to clean inside (works on Ds games)Turn on and off the Ds muiltiples off times and it should have work.I tried it and it worked.
Dec 27, 2008 | Nintendo DS Lite Console
Ds game cartridges
maby on the back of the game the gold strip got scrach or maby a water or something like that spilt on it
May 12, 2008 | Nintendo DS Lite Console
Nintendo ds games not working
With three boys we frequently have this problem and we found that rubbing the pins clean with a Qtip dipped in rubbing alcohol and then wait for it to be mostly dry before re-inserting. Some times we have to do this 2 times  - good luck!
Nov 30, 2007 | Nintendo DS Console
DS Lite won't recognize DS cartridge
a wire is probably misplaced.I recommend getting professional help or unscrew your ds and fixing the problem.
Oct 01, 2007 | Nintendo DS Console
Nintendo DS Console Logo
519 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
