Question about LG VX8300 Cellular Phone
Lgvx2000 Hello , I am using a lgvx200 cell phone. When I charged up the battery, it sezs battery charged, when i unplug the charger from the phone it dont stay on. When iI plugged the phone up whutout the battery, it tells me the battery is missing. But like I said at first, When I do connect the battery with the charger, It sezs Battery charged. Is it the battery or the Phone?
  • 133 Answers
Normally a drained battery would take about 30-40 minutes to charge, however if the battery charges in about 2-3 minutes or even faster (as in your case) the fault lies in the battery. If your phone isn't water dropped and is within the warranty period you will get a new battery. I would suggest u change the battery and check (maybe with another battery of a similar make) and then see the results before u could buy one.
Posted on Dec 15, 2007
1.The usb connection uses about 5v charge and is utilized from your phones battery.So charge become less.
2.If your charger pin is loose when you plug in the charger it shows "charging" for that instance only and it won't charge.
Try replace the charger
Jan 13, 2011 | Cell Phones
LG Neon won't charge. It's not the charger.
First turn off the phone remove the battery and put it back in, then try to charge it, make sure the charger is properly inserted in the phones charging port.
Try out the charger on another phone to confirm if it is still working. Then you try another charger on the phone to confirm if the phone is faulty. If the charger does not work, then the problem is from the phones charging port.
To repair that, have the phone opened then either resolder the carging port to the main panel or you replace the charging port with a new one.
For the main time, you can use a universal charger, but that will require you to have an extra battery so your phone will not be off when charging the battery.
Take care and good luck
Oct 28, 2010 | LG Neon GT365 Cell Phone
Hello, my INNOV8 betery is not charging, only shoes that is charging but if i unplug the charger then the batery shows empty!!! Other thing...if finaly i get to charge the batery is drains all the power...
Looks like you will have to replace the battery if it does not hold a fully charge and it's discharging fast. 80% that your battery is going bad. hope this helps
Oct 23, 2010 | Samsung SGH-i8510 INNOV8 Cell Phone
Code to be able to use any charger for a Motorola W385 Cell phone
There is no code to be able to use a charger on your phone.
You can try using a universal charger to charge the battery.
If chargers are not working on your phone, then it means the charging port of your phone is faulty.
Have it fixed and you will be able to use your charger.
Take care
Sep 13, 2010 | Motorola Mobility W385 Cellular Phone
My LG-VX9200 wont turn on and the battery wont charge. I assume is the battery, its a practically new phone. It hasnt get wet either. What can it be? Thanks in advance
Before you conclude that the battery is the problem, i suggest, you get a similar charger to charge your phone first, if the similar charger charges the phone, then, ii means you are having charger problem, but if it does not charge the phone, you should be considering the idea of getting another battery to see if it will charge on your phone.
The problem can also be that, the charging port of your phone is bad, you can use your charger to charge a similar phone and see if it charges, if it does, then, the problem is either th battery or the charging port.
Check the following one after the other to detect what the problem is,
1. Try use a similar charger to charge your phone to see if it will charge.
2 Get a battery from someone that as a similar phone to test your phone to see if it will power up.
If it works with your phone, get a new battery for your phone, the one you have on it is dead and will need to be replace.
Take care.
Jul 18, 2010 | LG enV3 VX9200 Cell Phone
Battery drained for Bold 9000. It just died on me.
Get the battery charge charged and power on your phone back after the battery has been charged.
Use the charger that came with your bold 9000 to charge your phone, if it does not charge it, get a similar charger to charge your phone and power it on after charging, ou phone will continue to serve back as before.
But if the battery is not charging at all, it means the cells of the battery are dried, so you will need to get another battery on your phone.
Take care..
Apr 30, 2010 | RIM BlackBerry Bold 9000 Smartphone
The charger slot on the phone does not work when plugged in, think it needs a new port
Why don't you use the charger to charge a similar phone or use a similar charger aside yours to charge your phone to see if it is the charger or the charging port.
If your charger charges a similar phone as yours, it means the charging port of your phone is bad.
But if it does not, the charger is the problem.
If it is the charging port, all you need to do is to replace the charging port and your phone will charge.
Take care.
Apr 21, 2010 | Samsung Instinct Cell Phone
My phone wont charge
Try to remove the battery and put it in a similar phone, charge with your charger, if it charges, it means the charging port of your phone is bad and will need to be replaced.
But if the charger did not charge your phone, it means the charger is the problem.
You can also use another charger to charge your phone to see if it will charge it, if it does not, it means the problem with your phone is the charging port.
Replace it and your phone will charge.
Take care.
Apr 21, 2010 | Motorola Mobility BT50 Cellphone Battery
Charging problem
there is nothing wrong with your charger. The problem is from your battery.
The battery cell is very weak, such that it does not have the ability to with hold power for long.
Therefore, get another battery and the problem will be resolved. But make sure you charge the new battery till its full before you start using it.
Take care.
Mar 10, 2010 | Nokia N70 Cellular Phone
LG VX8300 Cellular Phone Logo
231 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
