Viewsar ultra2000 reciever went blank. power still supplied to unit. sent to dealer came back and worked for short time. any idea what cause or area to check
    Problem Solver:
  • 9 Answers
Www.ftabins.net
Posted on Jan 06, 2008
What is the reason for my E701i-A3 failure? All boards were replaced, worked for a minute, and then had the same "fade to black" failure as the first time.
Your back light controller board or the ballasts for them may be bad if they weren't incorporated into the power supply board.
Dec 05, 2016 | Televison & Video
Intermitantly working v2 rangefinder
Had the same problem with my first Bushnell V2 (Slope). Worked intermittently and sometimes just quit altogether. Finally had to send it back to them. They sent it back and said nothing was wrong with it. I called them and told them they were wrong and I was sending it back and they should take more time in testing it. This time they acknowledged problem, said it was fixed and sent it back to me. I wound up getting a real good deal on the V2 without the slope calculator (necessary if you want to use it in championships). Used this one for some time with no problem, but now it just went dead again. Battery tests well into green area on meter, but I'm going to try a brand new one and see what happens. From all the things I've read about the V2 and battery life, it looks like you might need pretty fresh batteries to keep it going.
Jul 22, 2012 | Bushnell Tour V2 Pinseeker Laser...
While watching the TV the screen went blank and there wasn't any sound. I've checked all the cables. I tried turning it off and back on but when I did this the power light flashes 27 times before...
The tv power supply board it is shorted and dead.That the board where the tv power a/c cord plug into it.Tries websites like Shojimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 28, 2011 | LG 32LC2R 32 in. HD-Ready LCD Television
Last summer we installed a Intex salt water filter it worked great for about 2 1/2 months. It stopped working, Checked the power supply nothing was coming thur it. Intex relpaced it under warranty. Started...
This could be a flow problem and you will need to check your pump baskets for junk and make sure your filter is clean. Also you can check your flow switch to be sure it is working.
Aug 13, 2011 | Intex Automatic Salt Water System for ...
Suddenly went blank while in use no power lighttotally dead
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
May 11, 2010 | ASUS VW192S Monitor
Monitor went blank,I shut down monitor and powered up and it came on for 5 seconds then went blank. Tried on another pc and same result
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 04, 2010 | Computers & Internet
Tv goes blank while viewing
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that re-starting that gives it away, this is a typical switchmode Power Supply problem.
Jan 24, 2010 | Televison & Video
Optoma EP Portable Projector - No Power
if the lamp asssembly isnt screwed in tight the unit will not power on. i did have a faulty lamp once, try fitting the old one back to check first. if not the power supply is faulty on the main board or a short in the supply to the lamp can cause this fault.
Nov 01, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Black Screen
try this option , open the unit , look on the PC board , try to locate an inverter transformer ( its square with ferrite coil ) look on the back for a DRY SOLDER around that area , if not then try the POWER SUPPLY also , hope this helps
Apr 26, 2008 | Sylvania LC320SS8 32 in. LCD Television
Disply goes blank
The problem is most likely a burnt, loose, or cold solder connection on the control board. Most likely at the low-voltage transformer that supplies power the board itself. Carefully resoldering any suspect connections in this area should solve the problem. Be careful not to get too much solder on the connections that could short one to another.
Nov 03, 2007 | Panasonic NN-S753 Microwave Oven
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
