Question about Proscan PSVR72 VHS VCR
Proscan vcr display says locked help cant wath tv
  • 1 more comment
  • Anonymous Jan 09, 2008
    vcr says lock unpluged tried to turn on
    display says locked unplugged and tried to turn on no luck
  • Anonymous Aug 28, 2008
    My vcr wont turn on :( it just says lock everytime i touch a button
  • 80 Answers
You must have the vcr on child lock.should be somewhere on your remote to switch off or go through menu
Posted on Aug 11, 2010
I have a 40 inch proscan lcd tv which i connected a dvd player to it but i would also like to connect a vcr player to but dont know how. I've tried several times but not sure how can you help?
Hello, There are two options for connecting the VCR, one of which must be connected to the VCR with a standard coaxial cable into the TV RF connection. The second is the direct connection as you have connected the DVD. The question is whether the connection is currently available and what kind of connection there?
Mar 06, 2011 | Proscan 32LB30QD 32 in. LCD TV
VCR Display Panel
It sounds like the LED might be burned out of it. Is your VCR still under warranty? If it is, the manf. can replace it at no cost. Otherwise an LED doesnt cost that much to replace if that is the problem. Did it do anything else before the problem happened? Does it still work now? But you cant see the screen is all?
Oct 02, 2007 | Proscan PSVR65 VHS VCR
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
Problem with my vcr
with your remote just hold on the power button! and you will get a cheery hello!!
Jun 09, 2008 | Proscan PSVR65 VHS VCR
Proscan vcr plus gold stuck in lock
I just had the same problem and found a solution on the internet that worked. Hopefully you still have the VCR's remote control. Press and hold either the on/off, VCR1 or VCR2 button on the remote. I pressed the VCR1 button and held it for about 5-7 seconds. It released the lock and worked fine afterwards. The lock is some kind of childlock devise.
Mar 10, 2008 | Proscan PSVR73 VHS VCR
Ps27108 - have no remote
Proscan,GE and RCA remotes are all somewhat compatible...
Your remote can be replaced with RCA part # 240895....$20.00.
Next, What brand is your combo...do you have programming instructions for it ....? Try PS,GE and RCA TV codes............T.
Dec 21, 2007 | Proscan PS27108 TV
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Proscan vcr psvr70
Sounds like it's wired up wrong...try this:
take cable line to VCR in, VCR out to cable/receiver box(if you have one) then box to TV...it sounds like the vcr is getting the channels from the box and not the vcr...you will need to have the vcr scan the channels (round in the settings menu) You will also be able to watch and record 2 different things.
Oct 18, 2007 | Proscan PSVR70 VCR
My vcr lcd reads LOCK now and I can't access any menu functions
My Proscan PSVR74 turns on, says "Hello" and immediately goes to Stop and turns itself off. Is there any hope for this machine?
Joe
May 08, 2007 | Proscan PSVR73 VHS VCR
Televison & Video Logo
71 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
