Question about AOC CT700G 17" CRT Monitor
Monitor Repair I'd like to know how to get into any AOC monitors service manual I want to know what is the code to enter the service
I disconnect the cable that connects the CPU, the cables came off, I need the connecting diagram for the monitor AOC 1770, the combination of the cables in the connector to the CPU, thanks
Posted on Jun 26, 2008
A service installation in this inf is invalid error - AOC E970Sw
Go To Below official AOC Computer Problem Page For Your problem
http://www.aocmonitorap.com/root/anz/download_driver.php Hope It's resolve all Your Computer Problem,
Or
Still having Problem Then follow Us For Technical Support
Mar 21, 2014 | AOC Computers & Internet
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
Europe com
I recently bought an AOC E790Sw monitor. When I try to install the monitor driver using the method described in the manual, it gives a "a service installation in this inf is invalid" and there is a yellow exclamation mark in front of the monitor "AOC 1970w" in the device manager. I tried uninstalling and reinstalling, but the problem remains the same. I'm running windows xp pro. Thank you.
Oct 01, 2013 | AOC Computers & Internet
I HAVE A NEOVO E-19A MONITOR. ON BOOT UP SCREEN GOES BLANK AFTER ABOUT 5 SECS. TURNING OFF THE MONITOR THEN TURNING BACK ON BRINGS THE SCREEN ON FOR APPROX 5 SECS BEFORE GOING BLANK AGAIN. THIS IS REPEATED...
http://www.devicemanuals.com/guide/LCD/AG%20Neovo/AG-Neovo-S-19A-LCD-Display-English-Owner's-Manual-T1RjMU9Uaz.html
dlc.sun.com/pdf/820-0119-10/820-0119-10.pdf
http://www.scribd.com/doc/3082274/AOC-LCD-Monitor-786LS-Service-Manual
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
May 25, 2010 | Neovo AG 17" LCD Monitor
Blackout monitor
ur video cable should be replace
if helpful then rate me
Oct 20, 2009 | AOC LM729 17" LCD Monitor
Same problem--AOC monitor "goes to sleep" after an hour online
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you can't do the repair we offer a repair service, contact us for more details.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 09, 2009 | AOC 19LVWK LCD Monitor
Aoc LCD monitor problem
If some of the pins inside the monitor cable are bent or broken you can losr primary colors and cause this. Check them. If they seem OK try reseating both ends of the cable. If no go, then try the monitor of a differnt computer to see wether its the videocard or the monitor thats defective.
Jan 06, 2009 | AOC LM729 17" LCD Monitor
AOC LM729 17" LCD Monitor - Manuel
I assume you only found the 4 mount screws in the back... You also need to take off the front silver edging - it pops off with some negotiating, but if you find the right spots and don't pry hard it will come off clean without too much difficulty. Then take out the screws that hold the screen inside and it should drop out.
Jan 26, 2008 | AOC LM729 17" LCD Monitor
Lm720a 17" monitor switches it's self
try to resolder all lost contact on flyback transformer..............................
Oct 11, 2007 | AOC LM 720 17" Flat Panel LCD Monitor
AOC CT700G 17" CRT Monitor Logo
204 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
