Question about DeLonghi TRD0715T Oil Filled Radiator Heater
Heater size? Our shed is 10X10 x7 insulated .Is this heater to big to leave on at 60 degrees 24/7
  • 3 Answers
Use the timer
Posted on Dec 15, 2008
How do I leave the water heater when I go away for the winter
if you leave the heating on low to stop freezing is fine . Not sure how you water works but I would leave it on to stop freezing Also get some one to pop in once a week to check things are ok .
Mar 19, 2017 | Beretta Water Heaters
Water too hot
Hot water is most often 10 degrees colder when it arrives at your machine from when it leaves your hot water heater. In general hot water is 130 degrees Fahrenheit (54.4 Celsius) or above. Warm water is between 110 and 90 degrees Fahrenheit ( 43.3-32.2 Celsius). Cold water is generally between 80 and 60 degrees Fahrenheit (26.7-15 Celsius). If cold water is below 60 degrees Fahrenheit (15 Celsius), clothes are unlikely to be cleaned very well.
Jul 20, 2011 | Washing Machines
I have model 5805 and i seems to always run, never shuts off and doesn't get my childrens small room warm (10x10) thought room wasn't holding heat so i put my lasko tower heater in there and it worked just...
Sounds like the ceramic heater has lost it's ability to heat completely. In other words, it doesn't peak any more.
Can it be repaired? Possibly, but finding the part(s) may prove difficult. However, if you can safely disassemble the heater, I would recommend that you try cleaning the interior with a can of compressed air that has a straw nozzle (like you clean your computer with). It may simply be a case that it's clogged with dust and lint. Try not to disturb any of the electrical parts when you do this.
Hope this helps solve your problem.
Feb 28, 2011 | Lasko (7564) Heater
My heater makes a buzzing sound when u turn it on.
May be loose screw in frame, element is old or insulator is worn
Jan 10, 2011 | Patton PRH11 Electric Heater
Storage heater smelling when operating - no spills on / in it
Depending on the age of the heater, the insulation material would be fibre glass and totally inert so will not produce any odour. The fire bricks are also odour free. Check the wiring to the heater for loose connections causing heating of the cable or plastic insulation.
Aug 07, 2017 | Dimplex SS5858N Mid-Size Heater
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
My Cozy Heater sized and installed by professional will not heat
I'm assuming your heater is the little Cozy direct vent wall furnace, your room calculations are correct, and at 57 degrees your main burner is constantly on. If so, it sounds as if you have too low a flame which can be caused by a main burner jet with an undersized orifice (like a propane one that got in the wrong assembly line) or obstructed by dirt, inadequate gas pressure, or a main gas valve that is not fully opening.
Open the pilot light inspection door and look at the main burner flame height. If it is less than 2 inches or so, check out the three possibilities above. If the flame is very yellow and wandering around lazily, check the air intake on your vent cap for obstruction.
Jan 31, 2009 | Cozy (W352E) Heater
Hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Oct 11, 2008 | Dishwashers
Baseboard heater cadet model
Check the circuit it is plugged into first with a tester or something else.
If it is 240v there are two hot wires.
You have to examine it first for power and then I would check the thermostat next.
You could have an open element.
Mar 25, 2008 | Cadet Manufacturing 09950 Baseboard Heater
DeLonghi TRD0715T Oil Filled Radiator Heater Logo
77 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
