Question about Jensen VM9510 Car DVD Player
Brake override code
Hello i was wondering if u could tell me where to go or how to get the brake override code
  • 4 Answers
It depends on what kind of indash you have. some you can just ground the wire thats supposed to go to ur e-brake and it could work. sometimes you have to trick it into working, by grounding it of course. the manual of the stereo should say how to do it, but instead of connecting it to the brake put it to the ground cable
Posted on Dec 15, 2007
DVD bypass code for Jensen VM9216BT
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote,
listening for the beep for each number
entered
4: A new menu will appear. Touch the button that has the hammer/
screwdriver on it in the upper left-
hand part of the screen.
5: Select Brake bypass to "ON" and hit
the "X" near the bottom of the screen. There is the code.
Jul 16, 2013 | Jensen VM9216BT 7" Touch Screen DVD, MP3,...
I just pruchased a car with a jensen raio VM9412 and i do not have the pass code or the factory pass code
try this. Hit Setup On Remote.
Select Language.
Get Remote And Hit 5,4,3,2,1,0.
Listen For Beeps. Touch "Hammer/Screwdriver" Logo.
Select Brake Override
Switch To Brake Override "ON"
Now Hit Setup On Remote.
And Now Watch Movies.
thats the bypass code so it can be turned on while driving. hope it helps.
Mar 03, 2011 | Car Audio & Video
Hello I am seeing a blue screen and a lock on the bottom left corner. I am unable to change channels or input. Please advise.
Hello
Your Apex Tv is locked. You must unlock it and reset all the V-chip settings once more. To unlock it do the following.
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
1. To use the override code:
2. Hit the MENU key to get to the menus.
3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
OK.
Jan 11, 2011 | Apex Digital Televison & Video
FORGET THE PASWOORD CODE
Select Language.
Listen For Beeps. Touch “Hammer/Screwdriver” Logo.
Switch To Brake Override “ON”
let me know if it works.
Kim ( Owner )
KS AUDIO
www.ksaudio99.webs.com
ksaudio-99@hotmail.com
Apr 13, 2009 | Jensen Car Audio & Video
How to bypass the parking brake switch for an 06 jensen VM9411
Here is the solution
1/ insert the dvd movie
2/After the disc loads and plays you will seea blue screen telling you "it is unlawful to drive with a movie bla bla bla"
3/Activate the brake sequence and disable the blue screen using the hand brake,the switch method or anything else to give the unit its 3 pulses to disable that freakin blue scrreen.
4/Next,on the main remote press stop twice,then 1,2,6,4.
5/You will now see a hidden menu that says.
Region Code
Brake Override(I know you are droling by now)
Macrovision(Watch all the burned and pirates you want if this option is off)
Loader Version
Model Version
6/Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle
on ,off or witch region code you want.
7/This is what you want.
Region code 1
Brake override ON
Macrovision OFF
When your done,click SYS SETUP on the remote TWICE to save the settings and vingo.
Mar 09, 2009 | Jensen VM9510 Car DVD Player
Pyle override park brake code
You can run the brown wire to a ground and that should work for you. Would you happen to know the importance of the pink wire?
Dec 30, 2008 | Pyle PLTS76U Car DVD Player
BackGorund Change on a Jensen VM9311TS In-Dash DVD player
There is no e-brake override code. You have to hardwire it to bypass the e-brake. Take the peach-colored wire and ground it to metal inside the dash. Put a toggle switch inline on the wire and mount it somewhere you can reach it. When you get the blue screen when starting a movie, open the switch for 3-5 seconds, then close it again to reapply the ground. Your movie will start up, and you can then drive away with it playing.
Sep 24, 2008 | Car Audio & Video
Overriding e brake video defeat
Aug 24, 2008 | Jensen VM9510 Car DVD Player
Jensen dvd not showing
The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. If you have questions, private message me or post here.
This code DOES work.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
Feb 17, 2008 | Jensen VM9510 Car DVD Player
Bypass the parking brake for vm9412 jensen
Select Language.
this works thank you for posting this.
derek
Dec 25, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
95 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
