Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca d52w20 52 in rear
I brought this tv and it work fine just yesterday the picture just turned red.
I checked the test points and read 18vr .29g .29b. . I am a electronics grad, but a this time I only have a meter not my complete test set. can you help me.? carlton14@hotmail.com
  • ssutwin83 Dec 17, 2007
    When I turned the tv on all I see is a red screen with wave lines.
  • RCA Master
  • 5,138 Answers
Your RED tube is most likely to be shorted or the video drive ic on red crt broad is bad, one way of knowing more on this set disconnect the red crt broad, unplug it from red tube turn set back on then see what you have! let me know your outcome on this.If you need to know anything else i will try to help you if i can.
Posted on Dec 25, 2007
    Master:
    Sergeant:
  • 482 Answers
Hello, I would take it to a TV repair place, they will charge around $50 and let you know what the problem is with it. this is your cheapest way out, it you want to keep it. If you chose to take it please give me a fixya rateing. Thanks, Farren
Posted on Dec 23, 2007
Tv picture is blurred
YOU MUST REPLACE YOUR CONVERGENCE IC S
COST 400 DOLLARS
Jun 03, 2010 | RCA P52926 52" Rear Projection Television
I got dish net work installed yesterday and it worked fine but when i turned the tv on the next day it was nothing but static and i cant figure out how to fix it so whats wrong and how can i fix it?
Guest,
The static you are getting on your TV is because the TV is not on the correct channel or input setting. With the 311 receiver, there is either a coax or an RCA cable (yellow, white, red) going from the receiver to the TV. If you have a coax cable, the TV should be on channel 3 or 4 (usually channel 3). With the RCA cable, the TV should be on an input setting. You'll need to go through your input settings until you find the picture. Of course your DISH receiver needs to be powered on. I hope this helps.
Ray Calo
DISH Network
May 20, 2010 | DISH Network 311 2-Room System DTV...
2002 akai 54in. rear projection tv wont turn on
Unplug,replug the tv back an hour later.The tv should reset itself.More problems repost,see if i can help u.
Feb 20, 2010 | Akai PT5492S 54" Rear Projection...
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
RCA D52W20 52in Rear Projection TV/ Picture
Sounds like someone has put a magnet near it or picture projection from rear may have moved is the picture fine other than tinting?
Jul 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No Picture
where can i buy Deflection board for RCA D52W20
Jul 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Unusable signal
Had the same problem unplug the tv for hour. Had ours at the tv repair shop and it worked fine there brought it home now we have a great picture but no sound.
Jun 01, 2008 | RCA P52930BL 52" Rear Projection...
RCA P61929 picture problem...
The TV was working fine, some time during the night the power went out, its plugged into a surge protector, everything else works fine, the TV won't turn on, the fuse is fine, is there a reset switch?
Dec 06, 2007 | RCA P61927 61" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
