Dometic Rooftop RV Air Conditioner
Problem for Dometic Rooftop RV Air Conditioner
Crazy Heat
By crazyseagull on Sep 22, 2009
I have a Dometic Duo-Therm Ducted air conditioner with a analog stat. Some times in order to make the heat work I have to: set the stat to cool and set it to the lowest temp setting. Then I set the stat to heat and a desired temp.The heat works fine as long as I leave it on heat. If I just set the stat to heat it does not do anything. This is a nine year old unit. This does not happen all the time. It seem it is getting worse. It happens more often now. Dometic said to replace the stat and control board. That is an expensive fix. Any one out there have a similar problem ? The control box has a Model number 3107541.09 on a label if that is any help.If I disconect the heater wires and short them the heater starts up. I could separate those wires and install a new stat only for the furnace. The Air works fine.
Comments:
Sep 22, 2009
- I have the repair manual for the stat. It has a chart for the correct reading in all the modes. That will rule out the stat. Looks like the board is bad.
Sep 23, 2009
Oct 30, 2009
- Dometic sent me the troubleshooting manual for this unit. After removing the cover and checking the wires for proper voltage I found if i wiggled the switches I got the unit to work. The solution is the thermostat is faulty.
Best Solution
posted on Sep 22, 2009
Helpful)
drberry
Rank: Guru
Rating: 92%, 82 votes
I think that I would change out the thermostat only due to the symptoms you are describing. Think the control board may be fine however, the thermostat sounds as if the internal componants are going out. Good luck on your repairs
Dave
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Spoke to Dometic today. They think it is the board. A kit is $75. I am thiking about installing a house digital setback clock stat that uses batteries " - crazyseagull
Popular Solutions for Dometic Rooftop RV Air
Questions and Unsolved Problems for Dometic Rooftop RV Air
Do you recommend Dometic Rooftop RV Air Conditioner?
Answer
Answer
can i take an ac unit off of my old rv and put it on the top of my cargo trailer?
Answer
My RV roof top air conditioner has no power going throw the circuit board needing to replace the... (More)
Answer
model 59516331G9 on the comfort control center digital screen will show temp set for a short time... (More)
Answer
a/c and furnace wont work.I have a duo therm, model #59516.531 on my toyhauler with a 3107541.009... (More)
Answer
I have removed the interior bracket and outside I have removed the shroud. What is next? This is a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dometic Rooftop RV Air...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
