Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I'm renting a house in Mexico and the stove takes propane. I ran out of propane so of course the burners didn't light. I now have plenty of propane but the burners won't light now. I hear then click
I'm renting a house in mexico. The stove takes propane. Well, I ran out...replenished the propane and now the burners won't light again. I can hear them all clicking and smell tons of propane coming out but no fire. What now?
    Habit-Forming:
  • 62 Answers
Try lighting with a lighter stick
Posted on Jun 05, 2009
Primary burner won't light on electronic button propane stove
If it won't light with a match,then the orifice is plugged.If it will light with a match because you can hear the gas coming out,then your striker on the knob is bad.It's replaceable.
Apr 14, 2014 | Coleman 2 Burner Propane Stove 5430E700
Electronic ignitor on propane stove wont start
  1. Close all valves, including the one on the supply tank.
  2. Open valves SLOWLY starting with the tank. Safety valves are built in to prevent escape og gas if vales are broken off.
  3. Turn on ONE burner valve and, depening on the ignition type of your stove, light it. (some have an electric spark generated by a power outlet (120v) and make a sort of poping sound, some have a spark generated by a push button type mechanism.
  4. Once one burner lights, the others should light easily. Sometimes air gets in the lines, and this may have to bleed off, but it should only take a few seconds. -PS, make sure the stove is level, since gas tends to flow to the high spot.
Feb 20, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
The electronic ignition (piezo lighter) on my Coleman 2-burner propane camp stove just quit sparking to 1 burner. It still lights the 2nd burner. A fix?
I've had this issue a few times. Complete cleaning of the under side of the burner and all components of the ignition system fixes it every time.
The slightest bit of carbon build up is the probable cause. I would suggest cleaning the contact with 400 grit or higher emory cloth. This will remove any contamination from the ignitor,
Aug 06, 2012 | Coleman 2 Burner Camping Propane Stove W/...
I have an old propane stove/ range in the house we are renting and we cant read the dials to see what temp the oven is or evan if it is on bake we need to know the only number we found was 35-300243-05-0...
I found the following numbers on my Whirlpool Range:
Quality Control Reference: 35-300243-05-0 (Back of range)
Warning Sticker: 35-302251-05-0
Model: SF380PEWQ0 (Under removable burner lid)
Serial: FFE0204680 (Under removable burner lid)
MFG No.: P1141260N Q (Under removable burner lid)
Whirlpool has the manual here: http://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%204363409.pdf
Whirlpool has the parts list here: http://www.whirlpool.com/digitalassets/MLPDF/Repair%20Part%20List%20-%204363637.pdf
Dec 18, 2010 | Kitchen Ranges
Ran out of propane, Stovetop has ignitors and they seem to be functioning fine. When turning on knobs there is plenty of propane smell but the burners fail to light.
This is normal when you run out of propane. Depending on the length of line you have, there will be a delay in relighting it again because of insert air in the line. My advice to you is to first air out the house til the smell is gone. Then turn on only 1 burner with the igniter sparking and also hold a handheld bbq lighter at the burner to ensure that the gas burner lights when the air is finally purged. This should only take 20-30secs. If it takes longer, air out the room and try again. Use common sense and please be careful!
May 18, 2010 | Thermador Cooktops
I have a 6 burner Vulcan stove with a bad oven pilot light.
Hi! I have the same problem with one of my burners (I have a morice range). I changed the thermocouple, but it didn´t help. I contacted Morice in France and was told that the problem most sertainly was the coil inside the gasvalve. I don´t know if it possible to dismantle the ovengasvalve to check the coil. As for a burner valve, one should open the valve at the end were the gas goes out to the burner to locate this coil. Best of luck Lars?ui=2&ik=305879aaef&view=att&th=1244dff9c340942f&attid=0.1&disp=thd&zw
Oct 06, 2009 | Vulcan 36L Gas Kitchen Range
Dometic rm2620
After running out of propane light the other appliances first to get the majority of air out of the system, such as your stove top burners. Then push and hold the manual button for a few minutes to purge air out then try to light the pilot.
Jul 30, 2008 | Dometic RM2620 Refrigerator
Garland stove pilot light problem, again but different
I'm not familiar with Garlands. When I run into a similar problem with other stoves of that vintage (Wedgewoods, etc.) I trace the pilot lines piece by piece, from the manifold to the pilot burner, if necessary opening a connection or two to see where I'm getting gas and where I'm not.
Is there a needle valve for adjusting the pilot flame? Is there gas getting all the way to the pilot burner? When it's the pilot burner itself that's the problem, I take it apart, brush/blow/shake out the crud, and run a small drill (#79 or so) through the orifice.
Dec 19, 2007 | Garland H283 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
203 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
