Question about Mitsubishi WS-55809 55" Rear Projection Television
My tv green back drown when i first turn tv on. then it warm up and it get right
    Genius:
  • 1,694 Answers
Slow-warming green CRT = expensive repair....use as is...
won't harm you or TV.....................T.
Posted on Dec 26, 2007
Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jun 15, 2009 | Philips 26PF9966 26 in. LCD Television
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Try to adjust it in the Service Alignment Mode (SAM).
Jan 04, 2009 | Philips 26PF9966 26 in. LCD Television
43UWX10B problem with green
if you have a 2 IC convergence chassis they dont control the green , However if you have the 3 IC chassis the green is controlleed by the third IC these are usually STK4275 or simallar single amp ICs. Which type chassis does your hitachi have? Its possibly related to the digital convergence board if all resistor near the ICs are good. Do you have the service manual? I can post a link where you can get the full service manual if you need one
Mar 29, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Turns off every so often
Well guys I found that if one just reads the manual you may find the solution...Mine seemed pretty simple - the room temperature was too warm! I adjusted the heat in the house, the yellow Status light went off and...it works again!
Thanks
ndre
Dec 23, 2007 | Televison & Video
Tv won't stay on!
Check C506 = high failure item # 483512247584 680pf / 2kv
Dec 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green Screen
This might be a proble with athe green electron gun having a short between the cathode and the grid. This problem require the use of a device called a picture tube rejuvenator. to test and if need be clear the short.
Sep 11, 2007 | Samsung DynaFlat TX-P3071WH 30" TV
Red and green lamps look off center
Intermittant convergence alignment issues are quite common.
Either solder the convergence IC pins or better yet , change out
the IC's with first quality OEM spec or upgrade..............T.
May 07, 2007 | Mitsubishi WT-42315 42" TV
Mitsubishi WS-55809 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
