Question about Frigidaire GLTR1670A Front Load Washer
Front load Frigidaire Gallery washer
During the final spin cycle the washer does not spin the clothes at high revolution therefore they are sopping wet at the end of the spin cycle. The washer does toss the clothes at a light spin but never fast enough to get the water out of the clothes. Any suggestions
  • 6 more comments
  • mavanya Dec 21, 2007
    I have the same problem, but ONLY on the permanent press cycle (with press saver option). I have had repairmen out four times but no one can fix it or tell me what is wrong. The last guy (yesterday) told me it was from too much soap. He suggested I run the same load again and again until there was no soap and it should spin dry then. I have run the same load through for two days now (no soap) and it still does not spin dry. Any thoughts????
  • Dr_Bob007 Dec 25, 2007
    Inconsistent High speed final spin cycle.
    To overcome the problem I need to reduce the load in the washing machine (sometimes by about 50%) for the High Speed Final Spin Cycle to 'kick in' and finish the job.
    Once spun, remove those spun clothes from the washing machine and place them into the dryer. Then replace the balance of the previously unspun 'wet' load and re-run the final High Speed Final Spin Cycle again.
  • Anonymous Mar 13, 2014
    My washer will spin, but the clothes are really wet at the end of the cycle and can't be put in the dryer
  • Anonymous Mar 17, 2014
    water draines but won't do last spin cycle leaving clothes dripping wet
    the anti crease light is flashing and therefore wont wash and drain the load properly...clothes are sopping wet!
  • Anonymous Mar 20, 2014
    Maytag neptune front load washer Model mah6500aww. the time changes from 7 to 8 and back again. I can hear the water draining.
  • Anonymous Mar 27, 2014
    clothes still wet
  • Anonymous Mar 28, 2014
    washing cycles work extra rinse cycles work, but when it comes to the fast spin cycle it does not work it spins a very little slowly and then stops and moves back and forth slowly and then it stops and nothing happens then the wash cycle is over and my clothes are still wet with alot of water still left in the clothes
    Problem Solver:
  • 10 Answers
You are having a door switch problem change it out and you will have a new washing machine.
Posted on Dec 15, 2007
How to changethe door around on a front loader washer
Posted on Dec 29, 2009
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
Why does the washer stop during a load and "F 06"
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code
GENE
Sep 09, 2011 | Kenmore HE2 Plus Front Load Washer
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer cuts off at 7 minutes and will not do the
It be the carbon brushes are worn down on the motor, when it goes into the final spin.
Mar 09, 2010 | Frigidaire GLTF2940ES Front Load Washer
Doesn't spin the clothes dry on the final spin but spins at high revolutions without a load of clothes
I have read that if the pump is not draining the tub completely, there is an interlock that prevents the high speed spin from engagin. I have had debris caught in my pump several times (kids!!) with similar issues. There is a trap on the line leading from the tub to the pump which is "supposed" to capture debris, but it doesn't work all that well. Check your pump.....
Dec 18, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
1,695 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
