Question about Tenebril Lifeguard (12090605) for PC
Install on new computer
Can't install lifeguard on my new computer with order no.st32454177
    Sergeant:
    Champion:
  • 317 Answers
Have you tried installing the software with NO OTHER programs running?
I strongly suggest you uninstall the Lifeguard software, then installing it with EVERY other program (antivirus, antispyware, utilities, Office, etc) not running. It should work.
Give me a message when you are done and let me know if you have more information or further questions.
We are here to help you FixYa!
Posted on Dec 15, 2007
    Scholar:
  • 54 Answers
If by "new" you mean Vista, then it won't install.
Compatible Operating Systems:
Win98,WinME,WinNT 3.x,WinNT 4.x,WinXP,Windows2000
You should probably just check in at their homepage to see if a patch ever comes out, or even check with their support staff to see if one is already out. But as it is now, it will not run on Vista
I lost my password hdd wd 500gb. Is there a way to reformat it and take my lumps?
go to the wester digital website, download the appropriate data lifeguard tools for your drive and burn the program to disc. The website will give you directions to erase data by writing zeros to all sectors, thus wiping it ready or use.
Good Lick
Tt is a very straightforward procedure
Mar 10, 2015 | Western Digital WDBAAU5000EBK - 500 GB USB...
Can your use tetra lifeguard on cory catfish?
yes as long as you have a balance in your tank no reason you cant use it.
Oct 06, 2013 | Tetra LifeGuard 12 tabs
My toshiba satellite L675d error 10-f12-0003
You may have a bad hard drive. If you are able to log into Windows, run Western Digital Data Lifeguard Diagnostic software.
1. Download Data lifeguard:
Hard drive analysis software
2. Install the software and run an extended test on your main partition.
If the test fails, then your hard drive is bad.1. Purchase a new hard drive from a local Best Buy or other2. If you don't have the original restore CDs, order them from Toshiba
Best regards,abdielcomputer repair plantation
Nov 17, 2011 | Toshiba Satellite Computers & Internet
Just installed brand new hard drive, 500 GBs. Upsized from 40 GB. Could there be a problem in set-up using XP Home. Keeps saying read disc error occured. Says Clear/ Alt/ Delete to restart, not working.
There might be a problem with the hard disk. You should hook the drive up to another computer and run a hard disk diagnostic test on the drive, such as Data Lifeguard Diagnostics by Western Digital to make sure that the drive is okay, even if it is brand new.
Sep 19, 2011 | Computers & Internet
I'm trying to install WD Caviar Green 1TB in my Dell Dimension 4600. It appears as though the exhisting hard drive used a SATA connection w/molex power connection. I have tried downloading the WC...
I BELIEVE THAT WD PROVIDES A CD WITH "WD DATA LIFEGUARD UTILITIES." IF YOU USE THAT DISK AND SELECT "DRIVE TO DRIVE COPY" SELECTION. THIS SHOULD CREATE A CLONE OF YOUR ORIGIONAL DISK. SELECT THE NEW DRIVE TO BOOT FROM EITHER IN BIOS SETTINGS OR FROM THE BOOT SELECT "F12" OPTION.
THE PC SHOULD BOOT FROM THE NEW DRIVE IF SELECTED
ED P
Aug 09, 2010 | Dell Dimension 4600 PC Desktop
I just bought a hard drive from ebay as a second drive its a western digital 250gb ide drive but my pc will not recognise it as a storage device but it installed the drivers! what am i doing wrong?
Hi:
often when you install a IDE driv ne that is as big as yours, you often need to run the WD installation software first. The easy way is to go to the WD website and download WD Data lifeguard tools program. you can try running it with that drive as a slave, or you can just install your new drive by itself, and go from there
Nov 18, 2009 | Western Digital WD2500SD Caviar RE EIDE...
I installed a new WD Cavier 500 Gb hasr drive ot
Your problem could be that the hard disk is not ACTIVE.
Boot up with a DOS disk (floppy or CD or USB) and run FDISK, select 4 to Display Partition Info. If the C drive does not have A under Status then press ESC and select 2 to Set active partition and then set Partition C to active.
Sep 06, 2009 | Western Digital Computers & Internet
Computer won't detect new HDD as master when booting
You can do this!
1. Connect your 500gig drive as the slave of your smaller boot drive.
2. Go to http://freewareapp.com/western-digital-data-lifeguard-tools_download/ and get the Western Digital Lifeguard tools.
3. Run the executable to install WD tools.
4. Run that application.
You'll notice there is a Drive to Drive Copy utility. This will clone your new 500gig drive from the smaller drive. When the utility finishes copying the drive, shut down. Remove the smaller drive, and set your 500 gig drive as master/single. Reboot, and you should be running off the new drive.
It is possible that your old drive was an IDE drive and your new one is SATA. If so, you may need to enter Setup on the reboot, go to the Boot menu, and set the boot device to the new drive type.
Mar 02, 2009 | Computers & Internet
How do i make all the finals on my wd 500gig not read only so i can write to the folders
How this WD hard drive protects your data:Data Lifeguard™ is an exclusive set of data protection features, including shock protection, an environmental protection system and real-time embedded error detection and repair. WD's Data Lifeguard technology automatically finds, isolates, and repairs problems that may develop over the life of a hard drive.
Data Lifeguard Tools™ are software utilities designed for WD hard drives that work with the embedded Data Lifeguard features to make hard drive installation,diagnostics and repair both simple and worry-free. (Download Data Lifeguard Tools). So download the Data lifeguard tool and try it out
Dec 02, 2007 | Western Digital 500GB My Book World...
Tenebril Lifeguard (12090605) for PC Logo
Top Tenebril Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Tenebril Computer and Internet Expert? Answer questions, earn points and help others
