Question about Asrock AM2NF6G-VSTA Motherboard
AsRock Motherboard no video output. No beep, no nothing, the CPU fan turning
  • hpiuau Dec 15, 2007
    Bill AU thanks Lolita's solution. It is really the memory is bad. A wierd thing happened. When I changed memory the AsRock Motherboard works. However the 'bad' memory works on other computer but only not on the AsRock Motherboard. It was too late. It costs my job.
  • 385 Answers
First of all, not all the time memory is bad it gives a beep. So you might still want to verify that it's not the memory. Try the memory in another cpu or try another memory in your cpu.
If you have verified that the memory is not the issue, then your next culprit is the video card. Make sure the video card is working. Take it out and clean the contacts with a clean piece of cloth and then reseat it properly.
Please let me know when you have verified the above recommendation and if it works or not.
Thanks and good luck
Lolita
Posted on Dec 14, 2007
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
CPU
It is due to the Motherboard Capacitor Problem. Change the Motherboard Capacitor.
Sep 16, 2009 | Asrock P4I45GV R5 Motherboard
L7VMM2 ECS motherboard will not boot.
One long and two shorts is usually:
Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
You seem pretty comfortable with troubleshooting, so here is a reference document ...
http://www.computerhope.com/issues/ch000607.htm
Jun 14, 2009 | Asrock K7S41GX Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Sep 27, 2008 | Asrock 775VM800 Motherboard
Replaced CPU fan, now it won't boot up.
No beep codes means the motherboard is dead .
sorry David for your loss
Jul 30, 2008 | Asrock K7VM2 Motherboard
Hello I have a motherboard Asrock nothing works
check all possible connections from your power supply to the motherboard.
May 28, 2008 | Asrock M266A Motherboard
No Post
I always suggest this and many times I get yelled at, but I'm just trying to help...
Did you plug in both power cords? There are two, one is rectangular and one is a smaller square shaped connector.
If that's not it and you've tried pulling all the cards and devices (RAM, HDD, CD/DVD) then you most likely have a bad motherboard.
Good luck.
Dec 28, 2007 | Asrock GE PRO-M2 Motherboard
No video output,
hi, did u check the ram, try cleaning the contacts, or replacing it,
and as u say the fan is working that means the smps is switching on, so it could be ur motherboard, remove any addon cards and then check..enjoy
Dec 14, 2007 | Asrock AM2NF6G-VSTA Motherboard
Screen not showing anything
Some time the system will work due to insufficient power source this problem may occur replace SMPS and check the CPU heat by touching it. If it warm then the CPU is functioning. Else contact your nearest hardware vendor.
Hope this will solve your problem.
Nov 22, 2007 | Asrock GE PRO-M2 Motherboard
Asrock AM2NF6G-VSTA Motherboard Logo
133 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
