Question about Sony Ericsson K750i Cellular Phone
Navigation key not working properly - Sony Ericsson K750i Cellular Phone
  • 175 Answers
Hi there must go to your nearest service to replace your joystick, its a common problem for ericsson.
peace!
Posted on Dec 15, 2007
Nokia 302 change language
Find "Device language"
  • Press the Navigation key.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Device and press the Navigation key.
  • Scroll to Language settings and press the Navigation key.
  • Scroll to Device language and press the Navigation key.
2. Select language
  • Highlight the required language and press the Navigation key.
3. Exit
  • Press Disconnect to return to standby mode
Jul 06, 2014 | Nokia 6220 classic Smartphone
I need to set up a security code to delete my recent calls how so i set one up
From the home screen press the RIGHT SOFT KEY (Soft keys are located above the center navigation key on the Right and Left sides, usually denoted with a horizontal line on the key)
Scroll to the SETTINGS option and press the CENTER NAVIGTATION KEY to make the selection.
Scroll to the PHONE SETTINGS option, and press the CENTER NAVIGATION KEY to make the selection.
Scroll to the SECURITY option, then press the CENTER NAVIGATION KEY to make the selection.
Scroll to the PHONE LOCK option, then press the CENTER NAVIGATION KEY to make the selection.
Scroll to the desired option, then press the CENTER NAVIGATION KEY to make the selection.
THE DEFAULT SECURITY CODE IS 0000 (4 zero's)
To change the current code, scroll to CHANGE CODES, then use the CENTER NAVIGATION KEY to make the selection.
Scroll to desired code, then use the CENTER NAVIGATION KEY to make the selection.
Enter the security code, then use the CENTER NAVIGATION KEY to confirm the code.
You will be prompted to enter a new security code, ENTER THE NEW CODE and use the CENTER NAVIGATION KEY to confirm the new code. You will do this twice. I hope that you have found this information useful, and if I can be of further assistance, please let me know. Thank you for using fixya!
Jul 11, 2013 | LG A340 MobiPhone - Silver AT&T A340
My samsung monte slide makes a beep when i send a text, how do i stop this from happening
Choose settings for profiles info.png 1 Find "Profiles"
  • Press Menu.
  • Scroll to Profiles and press the Navigation key.
2 Select profile
  • Highlight the required profile and press Options.
  • Scroll to Edit and press the Navigation key.
3 info.png Select settings for incoming calls
  • Highlight one of the following options:
  • Call alert type, go to 3a.
  • Call ringtone, go to 3b.
  • Message alert type, go to 3c.
  • Message alert tone, go to 3d.
  • Keypad tone, go to 3e.
  • Volume, go to 3f.
3a "Call alert type"
  • Highlight the required incoming call alert and press the Navigation key.
3b "Call ringtone"
  • Highlight one of the following folders:
  • Default melodies
  • Sounds
  • Music
  • If you select Default melodies:
  • Highlight the required ring tone and press the Navigation key.
  • If you select Sounds or Music:
  • If required, highlight a folder and press the Navigation key.
  • Highlight the required ring tone and press Select.
3c "Message alert type"
  • Highlight the required message alert and press the Navigation key.
3d "Message alert tone"
  • Highlight the required message tone and press the Navigation key.
3e "Keypad tone"
  • Highlight Mute or the required key sound and press the Navigation key.
3f "Volume"
  • Highlight the required category and press Navigation key right or Navigation key left to select the required volume.
  • Press the Navigation key to save.
4 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
How to reset samsung s w299
Restore factory default setting
1 Find "Reset settings"
  • Press the Navigation key to access the main menu.
  • Scroll to Reset settings and press the Navigation key.
2 info.png Restore the factory default settings
  • Tick the required settings by pressing the Navigation key.
  • When the box next to a menu item is ticked (V), the setting will be reset.
  • Press Reset.
  • Press the Navigation key to confirm.
  • Key in the phone lock code and press the Navigation key.
  • If it is the first time you use the phone lock code:
  • Key in the phone lock code again and press the Navigation key.
  • The selected settings are reset.
3 Exit
My number keys only not working in N73, menu,navigation remaining all keys working properly,while using some keys some symbols appearing please help me
This usually occur in all devices due to frequent usage of the keypad.The membrane under the keypad gets damaged and you need to replace it and things will be all right then.
Jun 02, 2011 | Nokia N73 Cellular Phone
Hello sir my name is makarand kelkar i'm 4m mumbai my cell phone is nokia 5130 my cells kye pad is not work properly means navigation key of left & right & also go to key and music kye...
The Navigation key set can be changed, it will cost around Rs.250.... Just take it to a mobile repair shop and ask them to change the key navigation board. It is very simple, even you can buy the spare and change it yourself... But the music keys I'm Not sure they will work or not, because it is a well known complaint in Music series of Nokia and nothing can be done properly(so don waste time in spending money for music keys)...
May 13, 2011 | Cell Phones
HP Compaq nc6220 PC Notebook Boot sequence
1) Turn the laptop on
2) AS SOON as you see > F10 = ROM Based Setup, in the lower left corner of your LCD screen, press the F10 key.
3) You will see the headings > Main, Advanced, Security, and Tools.
Use the appropriate Arrow key to highlight Advanced. (Look at the Navigation guide to see the proper key to use)
Press the Enter key.
4) Use the appropriate navigation key to highlight > Boot Order
Press the Enter key
This will show you the Boot Order Sequence.
What you are doing now is just looking around. You haven't changed any settings yet.
If you need to change the Boot Order Sequence, you have to use the appropriate navigation key, and highlight Multiboot, and then press the Enter key. Disable Multiboot.
Save changes.
If you do Not save the changes, it will be like you have done nothing at all.
[The navigation guide shows you the key/s to press to navigate around in BIOS Setup.
You may see,
Page up/Page Down, or -/+
Left Side Arrow key, or Right Side Arrow key.
Enter key ]
If this is not what you had in mind, please post in a Comment.
Nov 25, 2010 | HP Compaq nc6220 Notebook
I have acer aspire 4736 laptop which I purchaged on 31st December 2009 from Bangalore. Since past one month, my up and down navigation key is not working properly, by default it starts scrolling down the...
I have acer aspire 4736 laptop which I purchaged on 16th nov 2009 from mumbai. Since past one month, my down navigation key is not working properly, by default it starts scrolling down the page.
so please help me with solution
Sep 27, 2010 | Computers & Internet
The navigator 6710 won't work as a phone only the navigation switches on. When you switch it on the screen does not show the menu or the contacts. Noen of the keys work except the start for navigation.
amazingly the auto zoom in out is not a software problem.. it's hardware problem nd that's is why nokia is not getting in to help as its gonna cost it alot. the problem is that the upper portion has become touch sensitive. the acceot key , hang up key,the two selection keys and the navigation keys are made touch sensitive "delibrately" or intensionly.
Feb 03, 2010 | Nokia 6710 Navigator Cell Phone
My navigation keys do not working properly
It might be your navigation key has a loose connection to your cellphone that is why sometimes it does not work properly... I am recommending you that you must change your cellphone casing
Jul 30, 2009 | Nokia N72 Cellular Phone
Sony Ericsson K750i Cellular Phone Logo
57 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
