Question about Hitachi 61SWX10B 61" Rear Projection Television
No sound My tv sounds goes off after a few mins. and then Its silent or it makes cracking noise every so often. When the sound is on it perfect?
We had the same problem with our tv. We had to take it to our local radio shack. It cost another 200.00 to fix, but apparently they have seen a lot of problems with the hitachi. They had to order a new module for it. You might want to check with someone who deals with and fixes tv's in your area.
Posted on Dec 29, 2007
Tv only stays on few min then sounds funny no picture. Turn tv off then back on ok for few min. Then same thing happens.
sounds like a fault with the logic board. that area controls the sound and picture. if it is it will need to be replaced. look for a chip on the logic board that may have a crack in it.
Jan 19, 2013 | Coby TF-TV3217 32 in. LCD TV
Every time I put headphones into my Samsung yp-p2 the sound cracks or goes silent, why?
Try the Bluetooth for headphones.. Also if it is under the warranty you should contact them.. sounds like a bad port.
Feb 20, 2018 | Samsung Yepp YP-P2 Digital Media Player
TV turns off by itself
Thus the line connected to a surge protector or some kind of line protector. This can be consider.
Or if this is a crt type tv. This could be a fault on high voltage section. Horizontal output transistor or flyback. But check also for loose connection/solder crack. That clicking sound may be the relay in action.
hope i give some correct input.
Apr 23, 2009 | Samsung PCL5415R TV
My TV is making cracking noise
Its the plastic cassing making the noise. If you press the tv together along the edges you will here a crack. Samsung and others did not use 99 cent padding between the plastic and the metal you need cushion padding. Its like not using a gasket or seal. Its a simple fix but the tv companies say its expansion.
Oct 30, 2008 | RCA 14F512T 14" TV
Loud cracking noise sounds like fireworks and wont get a picture
It seems you have loose or cold solder joint connection problem,causing a cracking sound.The solution is to reworks or resolder the solder joint connection in power supply section, audio section and inverter section...
Hope this may help you;
Regards,
VOTIT
Sep 25, 2008 | LG RZ-37LZ30 37 in. LCD Television
RCA 52" D52w20 problem
My goes off a few seconds after turning it on. It does make a funny sound, like static on the tv.
Aug 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Volume makes a cracking noise. sometimes there is no volume,so i have to slap the back of tv to get sound back
Hello Sgarmekiss:
That issue sound like you will need to have your small signal board repalced by a repair center.
Aug 14, 2008 | Protron PLTV-32 Television
Intermittent "static surges"
Ionic Breeze is no longer supported because Sharper Image went into bankruptcy as a result of these products proving to be ineffective.
Here is a Sharper Image article
Here is an EPA article
Jun 17, 2008 | Sharper Image Professional Plus Ionic...
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Hitachi 61SWX10B 61" Rear Projection Television Logo
79 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
