Make sure that you evenly space your dishes so all of them have space. at the end of the cycle do you see steam? if yes your heater is good and you are recurculating proper. the only thing it could be is that you are overloading it
Sounds like it may just need a good cleannig. The bottom arm is easily removable. Take it off and remove the screen and see if there's any gunk that has accumulated in there. Also make sure the drain hose is positioned in a way that it will create a water trap to keep drainage from re-entering the dishwasher after the drain cycle ends.
Glass filled up. I checked the temp immediately and was just 90. I checked the sink temp again and it was 119. thanks for the quick replay.
put a cup upright in the upper rack and turn the dishwasher on let run for about 2-3 minutes in wash mode open the door and see if the cup has filled with water? let me know how it goes
