Philips FaxJet 375 Plain Paper Inkjet Logo
Posted on Dec 14, 2007
I bought philips faxjet 335, tx error
When Im trying to send fax after it feeds the document I have a TX ERROR coming up on screen and the report types : receiver does not answer, when I know for sure that receivers fax is on. And I cannot find anything in user manual.. Some one please help
  • tigraj Dec 30, 2007
    Well, It is a new one.i only bought it 3 weeks ago and the phone part is working.I am using the phone all the time. (Its phone and fax in one machine). And I have a dial tone when im dialing somebody's fax number......
John Green
Level 1:
  • Contributor 35 Answers
  • Posted on Dec 25, 2007
John Green
Contributor
Level 1:
Answers
35
Questions
Helped
19448
Points
69
Sounds like your communication board is out or your phone line is not working when you unplug your line and put a phone on it can you get a dial tone? then your fax machine is probably broke
1 Related Answer
Coldcut
Karl Whisenand
  • 1554 Answers
  • Posted on Jun 04, 2008
SOURCE: FaxJet 335, tx error
call the number manually . and does it answer with a warble immediately or does the phone ring a lot and then answer.
your timeout may be set too short on the sending fax setup.
Faxjet 525 will not send faxes
it is never getting a dial-tone. Phone line should be plugged into the LINE port.
1helpful
Canon fax mp780 says 'ERROR TX REPORT' 'result NG', what do I have to do to to snd the document? The manual has no translation of error codes!
If you go into the fax tx settings and turn off ECM setting, the fax should send (at least it did for me when I had the same problem).
CANON IR2870 OFFICE COPIER, FAX CONFIRMATION REPORT QUESTION
user interface =>report settings => fax=>report on tx=>image of tx =>off
Installation of jetfax 335/356
What is your question?
Hook the phone cord to the LINE port of the fax machine.
2answers
Faxjet philips 335/365 paper problem
did you have a papaer jam?
there might still be a part of the jammed page in the fax machine
or your paper may not be putting the paper sensor down far enough.
Faxjet 335 system error 3
does the print head move freely back and forth on the carriage?
If it dioesn't then that will cause the printer to error out and may give you a error 3.
Not sure but try a little oil on the carriage and move the assy back & forth a couple of times then clean the carriage off with a paper towle and try turning it on. does it still error out?
3helpful
3answers
Philips faxjet 335/365
I tjust tried the link above and it didn't work this way.
First, you enter this : http://www.sagem.com/support/site/sagem_carte.php
Second select your country,
Third, below "Sheetfed Philips"select the model,
A new page is opened and let you select "User manuals" on the left,
In english, it takes 4.9Mo in pdf format.
I hope this helps you
Top Philips Office Equipment & Supplies Experts
matt martin
matt martin
Aron
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
