Question about Cooktops
Frigidaire 30in cooktop FEC30S6ABE
In late Nov. the large front eye switch went out and I called the local appliance guy to come and fix it. After replacing the switch, as soon as the eye would heat up it would blow that switch and the one for the other front eye. yesterday he replaced both of those switches and now both front eyes and the large back eye is out. I watched the repair man change the switches and all were installed corectly. Is this a frigidaire problem?
  • 38 Answers
SOURCE: Replacement dual burner Gaggenau CK594
A heating element is a ' load ' only and has nothing to do with 'line' a heating element consumes energy and a line supplies energy. The nomenclature for both is unambiguos. Line and load would indicate a switch or overcurrent device. We are referring to a heating element that is beyond the switch or overcurrent device. Applying a meter to the element with a good understanding of the fundamentals or having a clear diagram that indicates the function of the wires is the only safe way to proceed. Connecting indicator lights in series would never get through UL and your appliance would not have reached market. Obtain the information necessary as to the function of the conductors and connect them according to the manufacturers instructions to avoid violating the UL listing. See NEC 110.3(B) (NFPA 70): Listed and labeled equipment shall be installed and used in accordance with any instructions included. The equipment we are discussing is dangerous if not connected properly please be careful.
Posted on Jan 16, 2008
aborcass
  • 2651 Answers
SOURCE: rear eye want come on
sounds as if you have a wiring issue, somehow power is backfeeding into the other switch. aliitle too late but was the switch an exact match or was it a new substituted aprt, its possible that the manufactue either sent wrong part , or the new switch altough appears the same ,,wire terminals were in different locations
Posted on Nov 10, 2008
SOURCE: Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Posted on Nov 18, 2009
SOURCE: Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
We are having the same issues it sounds like as Larry is...
Posted on Jul 26, 2010
tunde007
  • 2382 Answers
SOURCE: The dual element on my electric smooth-glass
Hi, my humble advice to you is to call in the repair man to come and carry out a check and properly diagnose what the problem is.
You might be lucky to have a fuse problem which th repair man will find and replace it and if the element goes beyond the fuse issue, the repair man will be in the best position to determine if you are to purchase and install a burner module or buying a new cooktop...
So call in the repairman first.....
Posted on Sep 19, 2010
Frigidaire ceramic stovetop burner not working
The switch controlling the burner is just a voltage controlling unit (rheostat). It needs to be replaced
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Aug 30, 2014 | Cooktops
I have a Frigidaire cooktop, model #GLEC3689EBB. We prepared a dish for supper, went into the dining room to eat. Something smelled hot and when we went to the kitchen, another burner was glowing red (not...
Hello Friend, this is Z. Thank you for your post!
Based on the symptoms you are describing it appears that your Frigidaire cooktop may possibly have a faulty switch or EOC (electronic oven control). This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis.
Jul 07, 2014 | Frigidaire Cooktops
My frigidaire fef368gch was working fine and then the oven just stopped baking. It will broil but not bake. What causes this and how do I fix it?
Good Morning Shari,
I see that you are having trouble with your Frigidaire range, model# FEF368GCH, and the bake element not working while the broil element is. I suggest giving your appliance a hard reset, by shutting the power off at your home's circuit breaker, for 2-3 minutes. When power is restored, you will have to reset the clock by entering in the time and pressing start. Start a bake cycle, and if you notice that the bake element is still not working, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Apr 23, 2014 | Frigidaire FEF368GC
Fridgidare model number mef305pbwf eyes stopped working
Hello James - Thank you for your question! Let's try resetting the range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit back on. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the EOC (electronic oven control), a potential wiring failure or faulty elements. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
Jul 16, 2013 | Frigidaire Stove / Oven / Range Cooktop...
My cooktops eye stopped working
Is the oven not working as well? If it isn't working check your breaker for that appliance.
Oct 06, 2012 | Frigidaire FEC36S6EB
I have a GE 30 in. Profile JP350 Cooktop. The large, front and right control seems stripped and will no longer control the cooktop. Also, the part that it sits on at the cooktop is not protruding up as...
Hi sounds like you have a busted switch assembly, this is very much fixable the part is around $50, but you would need to remove the top of the stove which requires pulling the unit from the counter, this is slightly more involved, but definitely doable i would also change the knob. A more accurate name would be infinite switch.
Sean
Mar 28, 2011 | GE 30 in. Profile JP350 Electric Cooktop
One large burner element does not work, can the element be replaced? Price of replacement element? Thanks
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Jul 02, 2010 | Frigidaire FEC32S6 Electric Cooktop
Water boiled over into control knobs for the cook top elements.
Just fixed this problem and repaired the corner of the Ceran cooktop.
Disclaimer: These cooktops run on 220V and will kill you if you don't know how to work with electricity. If you're unsure, get some help.
The boiling water slopped out of your pot, and went over to your controls (knobs) and went down the shaft and into a component call "Infinity Switch". The water caused the switch internally to weld one of the two internal sets of contact points into a permanent position. The fix is to replace the
"Infinity Switch" that the boiling water spilled into. The Infinity switch is the component that the control knob slides on to.
In my cooktop one of the infinity switches failed and appears to damage the adjacent switch. Mine actually caught on fire and damaged the wiring and the connector. Hopefully you are better off. Since they were in such close proximity I replaced them both. For $20 you might consider the same. I replaced both to be safe and they were $21.47 each.
My cooktop has 4 elements 2 small, 1 large and 1 combined (small and large) surface. A large element was definitely damaged and possibly a small element. I ordered both. I mention this in case a multi-element was damaged on your cooktop.
You will need to contact either Jenn-Air or someone. Since you can't see an exploded parts list online, you'll have to use the schematic. It is in a plastic sleeve and it stuck to the side of the ventilator housing underneath the cooktop.
When you wire the new part in, make sure you have the wiring correct or when you turn it back on you will burn up the new part.
I hope this helps.
Apr 02, 2009 | Jenn-Air JED8430 Electric Cooktop
Rear eye want come on
Nov 10, 2008 | Frigidaire 26" Built-In Electric Cooktop -...
Cooktops Logo
254 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
