Question about Philips FaxJet 375 Plain Paper Inkjet
FaxJet 335, tx error
When Im trying to send fax after it feeds the document I have a TX ERROR coming up on screen and the report types : receiver does not answer, when I know for sure that receivers fax is on. And I cannot find anything in user manual.. Some one please help
    Genius:
  • 1,554 Answers
Call the number manually . and does it answer with a warble immediately or does the phone ring a lot and then answer.
your timeout may be set too short on the sending fax setup.
Posted on Jun 04, 2008
How do you print a send report?
Press the funktion button and then the report button activity report will be displayed in the display press ok.a report for the documents that you send and received will be printed out.
If you whant to switch the tX report permanently on-
Press the funktion button and then the dataregistration button,use the arrows to scroll to Report settings,press ok,select tx report,and change to -output yes,
Then there will print a report for every fax you sent
Jun 30, 2009 | Canon FaxPhone L75 Plain Paper Laser
Faxjet 525 will not send faxes
it is never getting a dial-tone. Phone line should be plugged into the LINE port.
Jan 28, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Konica Minolta Bizbub C253
To output a TX Report after every fax transmission, perform the following:
1. Press the Utility/Counter key.
2. Touch [3. Administrator Setting] on the touchscreen.
3. Enter the Administrator password (default password is 12345678).
4. Touch [OK] on the touchscreen.
5. Touch [7. Fax Setting] on the touchscreen.
6. Touch [7. Report Settings] on the touchscreen.
7. Touch [TX Report] on the touchscreen.
8. Touch [ON] on the touchscreen.
9. Touch [Exit] on the touchscreen to return to the normal copy screen.
Please send posotive feed back if this helps.
Aug 06, 2008 | Office Equipment & Supplies
Report of fax
Hey renzo737 - Follow these steps to have your machine print a report after you send each fax:
1)Hit the Fax button, then the Menu button.
2)Press the < and > buttons to scroll until you reach
TX Settings. Hit OK.
3)Use the < and > buttons to scroll until you reach TX REPORT.
Then hit ok.
4)First you want ATTACH TX IMAGE and then you want
PRNT FOR EACH TX.(it may also say as TX REPORT)
On your machine under TX report it may just say PRINT ERROR ONLY, which means only print if there's an error, or the PRNT FOR EACH TX. You'll find it easily. You want the print for each tx option. This will print a report and give confirmation that your fax went through after each fax. If you have any problems understandind this or need more help just give a shout.
If this solves your problem PLEASE rate this as fixed. Like I said if you need more help just add a comment and I'll be happy to assist you further. Thanks and have a good one.
Jeff
Jun 30, 2008 | Canon PIXMA MX310 All-In-One Printer
CANON IR2870 OFFICE COPIER, FAX CONFIRMATION REPORT QUESTION
user interface =>report settings => fax=>report on tx=>image of tx =>off
Feb 27, 2008 | Computers & Internet
Faxjet philips 335/365 paper problem
did you have a papaer jam?
there might still be a part of the jammed page in the fax machine
or your paper may not be putting the paper sensor down far enough.
Dec 22, 2007 | Philips FaxJet 375 Plain Paper Inkjet
I bought philips faxjet 335, tx error
sounds like your communication board is out or your phone line is not working when you unplug your line and put a phone on it can you get a dial tone? then your fax machine is probably broke
Dec 14, 2007 | Philips FaxJet 375 Plain Paper Inkjet
Faxjet 335 system error 3
does the print head move freely back and forth on the carriage?
If it dioesn't then that will cause the printer to error out and may give you a error 3.
Not sure but try a little oil on the carriage and move the assy back & forth a couple of times then clean the carriage off with a paper towle and try turning it on. does it still error out?
Nov 20, 2007 | Philips FaxJet 375 Plain Paper Inkjet
Philips FaxJet 375 Plain Paper Inkjet Logo
362 people viewed this question
Top Philips Office Equipment & Supplies Experts
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
