Question about Neff H5642 Convection / Microwave Oven
NEFF H5632NOGB/01 I want to remove my microwave for repair but I can't fathom how to extact it from its housing. It has grill/vents above and below which I presume retains it in place but I can't see how this can be removed. Hope you can help. Thanks, Frank
Open door, place hands in centre of roof, lift gently and move back. This reveals four screws that mount the frame to the outside wooden housing, remove these and then remove the frame. Now lift the microwave out of the oven housing.
Posted on Oct 16, 2008
Is neff h5642nogb microwave oven discontinued
Discontinued? how much do you want to spend? Replacement could be less expensive, better options and more features.
Old standard may be familiar, but is it worth repair costs?
Nov 21, 2014 | Neff Microwave Ovens
Replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
How to repair venting fan in neff micro/oven
what is the fault precisely?is the fan not working?If so, you have to remove the fan carefully after opening the panels & removing its thimble connectors & replace it, Voila!
Jan 03, 2010 | Neff B7740N0GB Microwave Oven
Microwave lights up and glass plate rotates but no heat. Also, unsure how to remove microwave from its surround within kitchen unit.
to almost all of the no heat microwave issues suggest calling company about warranty because the warranty may cover problems like these up to five years and taking them apart will almost certainly void it. Magnatron is likely cause for problem.
Apr 21, 2009 | Microwave Ovens
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
Neff H5642 1000 Watt Microwave
Sounds like the Magnetron may have collapsed. Probably not worth repairing. Check for burnt/browned components on circuit board/s. Burnt wires, insect or ant damage or soiling. Magnetron is the large-ish square metal object with lots of heat-sink fins on it. Check for discolouration. If nothing obvious, it's probably stuffed, If something is obvious, it's still stuffed, but it may be repairable.:::Spiceweasel.au
Apr 04, 2008 | Neff H5642 Convection / Microwave Oven
Neff H5642 Convection / Microwave Oven Logo
1,553 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
