Question about Lorex L154-81
Front Panel Buttons on front don't always work. Just the On/Off works. when I tap on the Circuit Board in certain spots then it will operate normally until I turn it on next time. Very erratic.
I had this same problem. Look at the circuit board behind the buttons, there are 3 connectors 2 white 1 black. make sure the black connected is seated properly, in fact check em all.
Posted on Mar 08, 2008
Buttons on control panel of refrigerator not working
The control panel will need to be replaced, the buttons and the circuit board are all one piece.
May 17, 2012 | Amana Refrigerators
Emerson LC320EM82S Unit works ok with manual buttons at top of set but Emerson remote and after market remotes wont work at all
Hello
The remote sensor inside the front panel of your TV is faulty. This is a three terminal device, can be located just behind the infrared window at the front panel of your TV. You have to open your TV, and unscrew out the front panel circuit board to access it.
Sep 05, 2011 | Emerson LC320EM8 32 in. LCD TV
My 61" RCA rear projection
When this occurs the first thing we examine at the shop is the front button curcuit board. or button assembly. Generally when those become damaged it can cause this. What is definatly a given is the processor of the tv is somehow recieving the command "put up the main menu" it recieves this command signal from ether the remote or the front panel button. Sometimes when people clean they use windex or other cleaner. sometimes this may get into those buttons and short them out. or in normal use mosture or just general use can cause this. When this occurs try pushing the menu button on the front panel... does it go away. The chances are if the buttons are damaged the board will have to be replaced. At our shop this repair will run 50 to 75
Jun 14, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
Maytag mdbh970aws; s/n 23600314eg performance of front panel touch pad buttons has gotten worse. now the start/cancel button will not work. not sure if problem with control panel, ribbon cable to circuit...
if I may suggest its always worthwhile to go to scrap yard and look for the same model and swap the input touch pad as they wear away and no longer make proper contact or go to the website and find a replacement part good luck eric
Dec 24, 2017 | Maytag 24 in. MDBH970AWS Built-in...
The remote get harder and harder to operate. It
Hi there.
There may be some residue inside between the buttons and the circuit board.
You can open the remote and separate the rubber pad and the board.
then use some Qtips and rubbing alcool to clean the inside of the pad where the buttons make contact(little round black spots) then clean the circuit board itself where the buttons make contact.
Try to remove the residues but do not rub too hard on the contacts, you don`t want to remove the black carbon coating that is what makes the contact. You just want them a dull(not shiny) black color.
If you do it right you`ll see an improvement but remember that those contacts don`t last forever.
Hope this will help Merry Christmas
Dec 23, 2009 | Daewoo DTQ-27U4SC 27" TV
GE Profile Spacemaker 2.0 - black buttons on panel for vent, boost, and light broke . Any way to replace the buttons and take the panel off?
I had the same problem. The front plate is tabbed into place and removes with a flat tip screwdriver and prying in various spots to pop out the tabs. Once the front stainless plate comes off, you need to get behind the black buttons. There is a circuit board behind the buttons, which they make contact with. The problem with mine was the circuit board pushed beyond two metal tabs that keep it in place, so that the buttons were unable to make contact. I used a curved tool to pull the circuit board back forward in front of the tabs and into place. I put the front plate back on and it works like a champ.
Oct 28, 2009 | GE Profile Spacemaker Over-the-Range...
Can i put my tv on input without the remote
If your tv's front panel isn't working at all and the remote isn't either, then there is a simple fix. The only thing is that you will only be able to control your tv with the remote only. You can disconnect pin 4 at the connector of P001B on the front control panel circuit board. That will disconnect all the tack switches but allow the use of remote. First take your tv rear case off (there is 3 small torx head screws on the rear input/output panel, remove these first. Then there is two torx head screws on the left, top, and right side of the case facing rearward and connecting the black rear portion to the front silver portion). Once the rear case is off, there will be the front control panel circuit board attached in the front of the tv that needs to be unscrewed. Once unscrewed you can see all the connections labeled with eithers words or numbers. On the P001B connector on the front panel circuit board, there will be a 1 on one side and a 5 on the other. The pin 4 is naturally directly to the left of the 5 pin. There will be a bundle of wires leading from the front control panel to the main board of the tv which is on the bottom of the tv. Disconnect this from the main board. Then follow the #4 pin wire all the way from the front panel circuit board, to the connector end that you disconnected (This will be easy b/c they are in a flat bundle side by side). Then just completely remove only the #4 pin connector wire from the connector end. Wrap the end in electrical tape, plug the connector end back into the main board, and put the tv back together and it should work fine with the remote only (the front panel buttons will no longer work).
Nov 28, 2008 | RCA 27F530T 27" TV
Toast button sticks and sometimes does not function. Sometimes it will work if it is jiggled.
I had the same problem which was getting worse. Eventually I took the oven apart by removing the feet, shell and front. Then I removed the circuit board on the front panel which has all the switches on it. We never use the "Defrost" function, so using a soldering iron, I swapped the "Toast" switch with the "Defrost" switch. The Toast function now works normally. I plan to get some spare switches for the next time one of these goes wrong. While I had one of them out I checked it out and a Panasonic P/N EVQ-PAE05R available from Digi-Key P/N P12192S-ND looks like it will do the trick.
Oct 20, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Wont turn on. EE on display
It's probably the control board inside the control panel. I had the same problem and it moisture shorted out the board. You can order a new one from Sears Parts for about $45
Jun 09, 2008 | Maytag M6Y12F2A Air Conditioner
Lorex L154-81 Logo
188 people viewed this question
Top Lorex Televison & Video Experts
Mohamed Ismail
Mohamed Ismail
Colin Stickland
Colin Stickland
Are you a Lorex Televison and Video Expert? Answer questions, earn points and help others
