Question about Linksys Wireless-G WRT54G Router
Conection problem I have a lnksys-g wrt54. It has bin working fine for the last year. the problem is that now my laptops will not connect. if I connect direct to the modem it works fine. ....Isabelo
  • mkuria Dec 15, 2007
    i cannot connect to my laptop
  • Anonymous Dec 18, 2007
    we added new computer to network and now router does not work wireless, only if i plug it directly into computer. Lights are blinking not steady.
  • 38 Answers
If you are using the highest level of encryption available, your laptop may not support it.
back up the configuration file then reset it and set it up to be used without any encryption then see if that works.
If it does then the encryption is your problem, this is only the case when using WPA 1 or higher.
Posted on Dec 14, 2007
Laptop wont connect to internet
Your laptop has a manual IP on it you will have to dis able the IP and make it automatic for it to browse the net would have been more detailed if I knew the operating system u are using
Dec 05, 2011 | Sony Computers & Internet
Everything seems to be fine, but
If you have tried it on several computers, then it seems there is something wrong with the HD or its cable. Are you able to use another USB cable with it to see if that fixes it? I'm assuming the power light is on, and you can hear the drive spinning?
I bought an external drive about 2 years back. It worked beautifully but close to a year after purchase stopped working. Being a technician, I removed the drive from the case and connected it inside my PC where it still works fine. The USB circuitry in the case had failed, not the drive, which was good for me.
Apr 11, 2010 | Seagate Maxtor 750GB One Touch 4 Plus...
Wireless router is not working
Go to Here for Linksys EasyLink Advisor (LELA). With this software you can monitor the routers status and troubleshoot.
Most trouble shooting involves disconnecting the power to the cable modem and the wrt54 router for about 10-20 seconds. Then plug in the modem until it lights, then plug in the router. The Advisor will then get a new address.
It also shows a graphic picture of your whole system.
I have a wrt54 and use this whenever I have a problem. I fix it then turn it off.
Hope this helps.
Good Luck
Feb 19, 2010 | Linksys Wireless-G WRT54GS Router...
Cannot access the internet through the router. Seems like the router and the modem are not communicating. When I bypass the router there is no problem.
make sure the router does not have the same ip address as the modem. change the last on the router xxx.xxx.xxx.001 to xxx.xxx.xxx.002
Jan 09, 2010 | Linksys Wireless-G WRT54G Router
Bridge or Repeter mode.
It is possible but you will need to flash the router with custom firmware.
Here is how:
http://www.dd-wrt.com/wiki/index.php/Installation
This is only possible if you have two wrt54-g routers that are of one of these types:
WRT54-G ver 1
WRT54-G ver 2
WRT54-GL
(there is a sticker on the bottom that can tell you what version it is)
This is the article that I followed and it workes great.
http://www.dd-wrt.com/wiki/index.php/Wireless_Bridge
Apr 29, 2009 | Linksys Wireless-G WRT54G Router
Laptop conection problem
Try system restore.
Start, all programmes, accessories, system tools,
system restore, go back in time, take a date it offers you,
Hope this helps
Regards
Richard.
Apr 20, 2009 | Computers & Internet
Can not conect wifi or ethernet on my Toshiba after upgrade
Dear Mr. Frost.   Their are no VISTA drivers for your model listed on the Toshiba website. Their are four pages of Win Xp or 2000 If Toshiba didn't have them written no one else will either.     I would suggest that you downgrade back to  Win Xp.  Sorry. Your Toshiba model link below:  http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1484712&rpn=PSAA8U&modelFilter=+A65-S126&selCategory=3&selFamily=1073768663&selModel=1484712|PSAA8U
Mar 15, 2009 | Toshiba Satellite A65-S126 Notebook
The cd wont work that i got with the wireless router
Yes you can install it without a CD you just need to call the Linksys tech support number and a tech will walk you through in manually configuring the router without the use of setup CD dial this number its free 1800-3267114 and yes your WII will work fine with it Lnksys will also be able to help you with that concern..
Hope that helps..............
Aug 06, 2008 | Linksys Wireless-G Broadband Router
Cannot maintain wireless connection
Try manually add the network. If the problems continue, I would turn the laptop in for repair/replacement (if it under warranty).
May 15, 2008 | HP Pavilion dv9730us Notebook
Wireles conection problem
I've run into this issue with USB wireless network cards from DLink, Linksys, and Netgear. For me, the issue was with the USB ports on the PC and not having enough power for the device, the connection would stay live for a random amount of time and then all of a sudden it would die (same thing would happen when resuming from hibernation or standby). I added a PCI card with a powered USB hub in it and it solved my problem.
Hope this info helps!
Jan 15, 2008 | D-Link DI 514 Wireless Router (DI-514)
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
