Question about Belkin F1DK102P 2-port KVM Switch
Belkin (F1DK102P) 2-port KVM Switch freezes
When using the hotkey (scroll lock scroll lock 2), my mouse & keyboard freezes & the switch does not bring up the other desktop for the 2nd CPU. We've check connections and everything is good.
Any other ideas?
We have the same model and the same problem. The scroll lock combo did not work for us. You need to press Ctrl, Ctrl then up or down arrow.
The manual was a load of old Tom *** as it did not mention this.
Chard101.
Posted on Aug 19, 2009
I have detected the main causes of the mouse freezed on startup when switching between two computers. The problem isn't come from belkin 2 ports KVM switch itself. The problem is because I hook up 4 ports USB hubs to second PC. Remove the USB hubs will solve the problem. I have connected 2 PCs with one LCD monitor and now it works fine for me.
Posted on Jun 02, 2009
Port KVM Switches, KVM Switches, KVM Console, LCD KVM Console, KVM Console Switch, IP KVM Switches, KVM Console Switches dealers in India and KVM Console Switches suppliers in India.
Formore details please visit http://www.kvmconsolesolutions.com/
Posted on May 07, 2012
  • 4 Answers
Switch connections from pc1 to pc2 and boot up pc 2 first make sure everything works and then boot up pc 1 wait 2-3min then tre the switch
Posted on Dec 20, 2007
Cannot invoke hotkey function to switch computers .Directions say use num loc key plus minus key and release num loc but this doesnt work.
Make sure your keyboard and mouse are plugged into the correct usb slots on the switch. One is labled for keyboard, and the other for mouse. If you mix these up, those hotkeys will not work! :) Also, a much better hotkey for this switch is to tap scroll-lock twice. This automatically switches, so you don't have to hit multiple buttons.
Feb 18, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
IOGEAR KVM gcs632U. Set up notes that to "toggle" between PCs you press SCROLL LOCK twice. My keyboard has no SCROLL LOCK so to change you are supposed to press NUM LOCK + "-"...release "-" after 1...
OK well usually in the "Setup" you can "Assign" whatever keys you need, so can't you change the keys used to what you have? ALL Keyboards have scroll lock, it is probably just "Hidden" for instance I found one accessed via pressing a Blue Fn Key and then F12. Look carefully for "Other: small writing on keys.
Feb 15, 2010 | IOGear GCS632U 2-port KVM Switch
I have a justcom jc102cpa kvm switch and I need the hotkeys
KVM <====> Keyboard, Video, Mouse
Note that 'AUDIO' is not part of the "KVM" switching feature.
Dec 11, 2009 | JustCom JC-102CPA KVM Switch
Can't switch
Make sure your keyboard and mouse are plugged into the correct usb slots on the switch. One is labled for keyboard, and the other for mouse. If you mix these up, those hotkeys will not work! :) Also, try tapping scroll-lock twice to switch. It's much better than trying to use the num-lock + and - keys, since it's only a two-way KVM. Tapping Num-lock twice automatically switches, so you don't have to hit multiple buttons.
Oct 24, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Not working
Make sure your keyboard and mouse are plugged into the right USB ports on the switch. If you plug the keyboard into the mouse USB port the hotkeys will not work! The USB ports on the KVM switch are labeled under each port, with a mouse and keyboard icon respectively.From the Quick Start Guide/Manual: The Numlock hotkeys are listed as:
[Num Lock]+[-] [1] Switches to output 1
[Num Lock]+[-] [2] Switches to output 2
[Numlock]+[-] [A] Auto-scans and chooses which ever port is connected.
Alternatively: Tap [Scroll Lock] twice to automatically switch between ports.
Note: I've never been able to get the Numlock key combinations to work correctly. I always just use double-tap [Scroll Lock] trick to switch.
If you get stuck with your scroll-lock and Alpha lock lights flashing, just hit [Esc] to fix it.
Source: http://www.aten.com/download/download.php#productGuide (Scroll down to "Quick Start Guide" and choose CS62U out of the drop down).
Oct 03, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Don't have scroll lock on wireless keyboard/mouse combo, what other hot keys can i use?
You can try CTRL CTRL instead of scroll-lock. it was working for me. It is not mentioned in the manual.
Mar 10, 2009 | Belkin F1DK102P 2-port KVM Switch
Cannot unlock Keyboard Scroll lock - EX110
Found this little bomb shell after about 30mins of looking for an answer.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9220
To toggle your scroll lock key:
  1. Click on the Windows Start button.
  2. Select Run.
  3. Type 'OSK' in the dialog box.
  4. Click on OK.
  5. The Microsoft on-screen keyboard will open. Notice that the slk, or scroll lock, key (located in the top row of the on-screen keyboard as shown below) is turned on.
  6. Click on slk (in the top row of the on-screen keyboard). This will toggle the state of the scroll lock key. Notice that the scroll lock key is no longer outlined in red. Scroll lock is now off.
NOTE: If you have installed SetPoint (Logitech’s Mouse and Keyboard software) the confirmation message Scroll Lock Off will also be displayed for about 2 seconds on your monitor.
Yipee!!!
Aug 21, 2008 | Logitech Cordless Desktop EX110
Scroll lock light is on.keyboard keys will not function, cant log on computer. how to turn off scroll lock, as toggle. if hotkey has been assigned to scroll key, I am not aware of the key sequence to...
Is this on a laptop or desktop PC? Does the Scroll Lock button not toggle the Scroll Lock LED? Make sure the keyboard is plugged in all the way, and is not plugged into the mouse port (if it's ps/2 and not usb)
Jul 17, 2008 | Belkin Computers & Internet
Driver
you don't need a driver. to switch pc, use keystrokes below.
' Scroll Lock / Scroll Lock / 1 or 2'
'1 or 2' being the pc location on the switch.
hope this helps.
Mar 04, 2008 | KTC IntelliView KC102P (DSKTCKC102PS2)...
Hotkey mode
This just worked for me. Using your PC keyboard, boot up to the PC first and then power up your mac. Hit the scroll lock twice and IMMEDIATELY hit enter. You have to go fast- click-click-click with no hesitation and it works great. I still can't toggle the hot keys to set up my mac keyboard, which I prefer using, but I'm assuming it takes the "right" timing on the keys. I'll keep trying.
Oct 23, 2007 | IOGear GCS632U 2-port KVM Switch
Belkin F1DK102P 2-port KVM Switch Logo
1,505 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
