Question about HP Pavilion s3020n (882780985063) PC Desktop
HP Pavilion s3020n memory upgrade
I bought memory to upgrade my HP Pavilion slimline s3020n computer. I opened the case but need to remove the optical drive to get at the memory modules, how do I remove the optical drive?
  • Anonymous Mar 15, 2014
    how to remove hard drive from hp pavilion slimline
  • 62 Answers
They are usually in a plastic caady which has a latch on it find the latch and release the caddy hope this helps
Posted on Dec 15, 2007
Replaced motherboard &hard drive in hp pavilion, now it will not recognize reovery cd
By replacing the Hard drive you have removed the recovery partition with the operating system on it.
Did you make a backup of the Operating system to a set of CD's or just the Data?
If it was just the data you need a new operating system through HP Tech Support. The instructions are here
EmptyPortlet
Feb 13, 2013 | HP Pavilion Slimline S3020N PC Desktop
My hp pavilion slimline s3020n pc is on but cannot view on the screen it says on the monitor VGA: no input signal
Check the video cable connectors, remove the video connectors and reconnect them again.
Check the monitor input settings make sure the input is set to VGA and not to DVI.
Try a different monitor.
May 20, 2012 | HP Pavilion Slimline S3020N PC Desktop
Hp pavilion slimline s3020n PC the computer says no analog signal the problem is all the time cant run the computer at all.i have not tried to fix the problem myself
Does the computer turn ON? (do you hear beeps?, do you see lights on the computer NOT THE MONITOR?, do you hear the fans?, etc...) it could be the monitor, try an other one, it could be the video card, swap it with a known good one ,it could be the VGA cable change it, etc... if the computer is all dead try an other electric outlet.
Jan 13, 2011 | HP Pavilion Slimline S3020N PC Desktop
How do I get the DVD out of my s3100n slimline pavilion HP in order to install add'l ram
Most slimeline cases have DVD that remove from the front. That is you will have to remove the front plate of the computer to slide the DVD out. Close to the inside corners on the front usually are compression fit plugs that snap into place, ocassionaly screws but not often. Take your time and slowly push them outwards once you have all of them loose on one side you can gently rock the front back and forth until the other side dislodges.
It is important to not use excessive force or you could break the pins in which case you will need to have some glue handy.
Feb 05, 2010 | HP Hewlett Packard Pavilion Slimline...
I want to upgrade the RAM, and when I opened the desktop the dvd is positioned over the memory slots. I CANNOT FIGURE OUT HOW TO REMOVE THE DVD TO SWOP OUT THE RAM
see if there the motherboard is secured onto a rack that can slide out of the casing. most newer computers have this feature. if not, you will have to unscrew the dvd drive from the casing to get to memory slots. unplug the drive, find the mounting screws, and remove the drive. remember to plug everything back up (power, interface cable, digital cable if present).
good luck.
Oct 15, 2009 | HP Hewlett Packard Pavilion Slimline...
Cant Remove Optical Drive to add memory
At HP's web site, the instructions mention removing a screw on the side of the CD to remove it from the box. Try looking here. (If that link doesn't work, go to www.hp.com and in the search window, enter S3020n. Click on Help & Troubleshooting, then Setup and Install, then Adding & Removing Hardware. There's a link to replace the CD there. They also have PDF versions of the manuals.
Dec 22, 2008 | HP Pavilion s3020n (882780985063) PC...
I have a HP s3020n slimline the pc is running but not sending any signal to the monitor
Well... try un-plugging the VGA cable... ie., the monitor cable behind the tower...... if u get a message on screen saying No VGA Input... can confirm there is no issues with the monitor...
if you are using graphic card in computer unplug that and connect the VGA cable to normal display card came along with the computer and try...
or if you have another monitor... u can try connecting that to the tower which is not sending the signal to monitor and try....
even then you get the same problem... get an new graphic card... (if you dont have other monitor try with new graphic card)
Aug 24, 2008 | Computers & Internet
Low profile video card for HP Slimline Desktop
Upgrading a certain parts in the computer depends on what purpose you want it to perform. If you're a GAMER or using imaging sofwares, then use MidRange Video Cards, like 7600GT. If the space on your Casing is very tight, then using low voltage Video cards like 7300LE.
Jun 11, 2008 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
HP Pavilion s3020n (882780985063) PC Desktop Logo
364 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
