Question about HP 1040 Plain Paper Inkjet Fax
Fax Window shows only 8 Black rectangles
AFTER PUTTING IN A NEW BLACK INK CARTRIDGE, THE # WINDOW DOES NOT SHOW ANY NUMBERS OR MESSAGES DESPITE MY HAVING DEPRESSED THE MENU BUTTON AND THEN HAVING DEPRESSED THE NUMBER 1.
iTRIED UNPLUGGING THE FAX , BUT THAT ALSO DID NOT SOLVE THE PROBLEM.
aNY IDEAS?
  • 1 more comment
  • jrjenk Jan 09, 2008
    lcd problems
  • maur56 Feb 13, 2008
    changed ink cartridge cannot receive faxes
  • activeimage Apr 12, 2008
    Same issue here. Just have the 8 black rectangles. I've replaced the ink cartridge but can't make copies or fax at all now, I just get the annoying beeping sound when i try to do anything? WTF's up.
    Genius:
  • 2,120 Answers
If you unplugged and re-plugged and that didn't fix it, it's toast.
Posted on Sep 01, 2008
Canon 5220 prints - NO ink
Try running the cleaning program.
Mar 20, 2014 | Canon Pixma MG5220 InkJet Printer
I dont have ink yet but i still have black.. what will i do now if i print black and white but when its printed it turns to pink? hope to hear back from you..ty
Hi karencruz417...
If you want to print only in black, then what you will need to do is click print and when the window pops open to show your printer you will click on "Properities or Preferences", the when that window opens you will click on the tab "Color", then another window will open and you will put a check the box "Grayscale", then mark the circle with a dot on the words "Black Ink Cartridge Only"
Now you are ready to use the black ink only and no Pink will show up
Please take time to rate me
Aug 21, 2011 | Computers & Internet
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Brother MC420CN- Black ink cartidge 'near empty' message persists
At 1 of the end sides of the cartage you will see a little window, a beam of light hits that window to determine if you need Ink..Place a small piece of Electric tape over that window and.wallah print,fax and copy away. Brother is a ripoff-A cheap printer that auto-cleans(wastes ink) and locks the whole system claiming your out of Ink or low>>>But this is sure to work! ;)
Nov 01, 2009 | Brother MFC 420CN All-In-One InkJet...
Fax will not print test page comes out blank
Try another cartrige or clean the contact points of your print head.
Jul 29, 2009 | Samsung SF-350 Plain Paper Inkjet Fax
My HP Printer does not show color. When I print black and white, I get a pinkish cast and often pinkish printing.
It is possible you're black cartridge is too low on ink & needs replaced. If you're black ink cartridge is new, there could be small ammounts of sticky tape left over the contacts of the ink cartridge. Please clean the ink cartridge's copper contacts (side only, not the bottom of the ink cartridge), with a cotton swab & a little alcohol. Since the ink cartridge is removed clean copper contacts inside the carriage holder as well. Allow time for the alcohol to dry. All most every printer installs software that monitors ink level's. To check you're printer for this. Click the start button, slide up to & click Printers and faxs. The printer and fax window will open. You're default printer will have a little check mark next to it. Right click once on that printer name, another little pop-up window will open, slide to & left click on properties.
You're printer (It's name) will open. Near the bottom click on Printing Preferences. Another window will open. Click the Services tab. Than click Service this device. You should be able to see the ink levels.
Have more questions? Please feel free to ask.
Hope this has helped.
Luck!
Mike
May 12, 2008 | Office Equipment & Supplies
No Cartridge
i am sure this is the same problem as the 440cn. each cartridge has an optical window on it where the sensor measures the ink level. what u do is put a folded piece of paper over this window and reinsert the cartridge. this makes the sensor think that cartridge is full and should reset the ink meter. the printer should work fine.
Jan 30, 2008 | Brother MFC-665CW All-In-One InkJet...
Intellifax 1860c no cartridge or replace ink keeps showing up
I have 1860 fax machine. It says that the black cartridge needs replacing. I buy a new cartridge and put it in and is says to install a black ink cartridge. I reinstall the cartridge several times and it says to install a black cartridge. Any help before I smash this piece of **** fax machine in the driveway?
Aug 08, 2007 | Brother IntelliFax-1860C All-In-One InkJet...
Black Rectangle Appears on Screen
Perhaps the caption is on?
May 27, 2007 | JVC AV-27220 TV
HP 1040 Plain Paper Inkjet Fax Logo
mukhtar21 shaikh
mukhtar21 shaikh
