Question about Toshiba MK4026GAX (hdd2193) 40 GB Hard Drive
Jumper Positions on the TOS MK4026GAX drive
I need to try and slave this little drive on a desktop (minitower) PC; but I can't figure out which jumper position is best. No matter how I jumper it; the primary drive won't boot into Windows. The drive circuit board isn't labeled for using jumpers (naturally), so I've been doing the "trial and error" method.
Any help is appreciated. Thanks.
  • Jim Golec Dec 15, 2007
    Thanks for replying, Lolita.
    The primary drive is actually jumpered for Cable Select. If I set it to Master, would that make any difference? I'm also wondering which set of pins to use on the laptop's Hard Drive. I'm presuming that either would work; since the BIOS detects both drives at this point.
  • 385 Answers
Check the primary drive. Maybe the jumper for that is set to master/SINGLE drive. You need to change it to accept a slave drive alongside it.
Let me know if this helps.
Posted on Dec 14, 2007
Cant find the slave drive on boot
Master/Slave configuration I am assuming you have IDE hard drive and not SATA. SATA is a small cable IDE is a wide 40 wire flat cable. You must install the jumper on both drives as master and slave. On the old WD HDD master has jumpers between 5 and 6 and slave jumper between 3 and 4. Default is jumper between 1 and 2 which is cable select which you use for a single drive.
Nov 09, 2013 | Dell Inspiron 531s Desktop Computer
How connect slave drive dell computer?
I assume you are trying to add a slave drive to a Dell DESKTOP? If so, is it an IDE drive (standard hard drive). To that you will find a jumper plug, usually beside where the cable plugs in but sometimes on the opposite side. The jumper options are usually listed on the drive but what you will need to do is place the jumper plug in the slave slot. You will also need to move the jumper plug on the original hard drive to the master slot. That always seems to work the best for me. However, you can try adding plugging the slave drive into the next open slot on the IDE cable, which is already plugged into the original hard drive. If you get lucky it may automatically recognize the new drive as the slave. You may need to setup/configure the BIOS to set the master and slave drives. To check BIOS setting, hold F2 or F10 when you turn on/boot the PC.
Apr 20, 2012 | Dell Computers & Internet
Slave jumper settings for a 2.5 Hitachi DK23DA-20F hard drive
Most hard drives I've come across have tiny little letters on the PCB next to the jumpers that say MA SL CS which are for master, slave, and cable select. If that doesn't work, go to Hitachi's website and search their support section. There is a diagram of the jumpers for that drive out there somewhere. Good luck!
Nov 07, 2009 | Hitachi (DK23DA-20F) 20 GB Hard Drive
The master hard drive died. I bought a new drive,
Just check the harddrive connector diagram on the hdd itself it shows clearly the way to connect jumper settings.
Aug 17, 2009 | Computers & Internet
Western Digital 80gb HDD Fails when installing OS
Try changing the jumper settings to make it the Master instead of the slave drive
Mar 23, 2009 | E-Machines eMachines Desktop PC
I need jumper settings for samsung hd080hg/j drive
Setting the order of the hard disk drive (Master, Slave) Jumper Location There are three cases of the installing jumper(shunt) if the jumper is located in the middle of connectors as above.
They are Lower 32GB, Upper 32GB and With capacity limitation in upper 32GB.
Feb 18, 2009 | Computers & Internet
Hi i have a 10.1gb Maxtor model 31024H1 IDE hard drive and i need the jumper setting for slave
slave is NO jumpers at all
(Master) - The vertical jumper over the J50 pins is configuring the drive as a Master. The horizontal jumper over the J48 and J46 pins is in the Storage position.
(Master with CLJ) - The vertical jumper over the J50 pins is configuring the drive as a Master. The vertical jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Slave) - No jumper is required to configure the drive as a Slave. The jumpers over the J48, J46, J44 and J42 positions are both in the storage position.
(Slave with CLJ) - The jumper over the J44 and J42 positions is in the storage position. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Cable Select) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J44 and J42 pins is in the storage position.
(Cable Select with CLJ) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
Oct 13, 2008 | Computers & Internet
Replaced teac dvd-r/cd-rw drive in Toshiba 2435-s255 running Windows XP. System does not recognize new disk drive.
if you put it on the same ide ribbon as another drive then youll need to set 1 as master and 1 as slave, theres a jumper setting on the back of your drive. on the top of your drive it should tell you were master is and were slave is, youll need to pull the little black plug out (jumper) and move it to where you want it to be, i.e master or slave
hope it helps
Jun 13, 2008 | Toshiba Computers & Internet
Using master, slave or cable select jumper
89c8602.gif SETTINGS:
A - Cable Select Mode
B - Slave Drive Mode
C - Mater Drive Mode
Mar 01, 2008 | Lite On (LTN486S) Internal 48x CD-ROM...
Hard disk
you have to have both drives share the ide cable.on the back of each drive you will see a jumper,you will also see markings cs,mas,slave.the drive you want as master use the jumper on cs (cable select).the drive you want for slave use the slave jumper.if you just want to use your new drive put the jumper to cs first if that doesnt work put the jumper to master.
Jan 07, 2008 | Compaq Presario 5000 PC Desktop
Toshiba MK4026GAX (hdd2193) 40 GB Hard Drive Logo
637 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
