Question about HP Photosmart C6180 All-In-One InkJet Printer
PAPER FEED Get constant error msg that there is no paper in tray.
  • 3 Answers
Call 1-800 HP INVENT (1-800-474-6836)
Posted on Jan 05, 2008
Constant Paper Jam
check the wheels that pick it from the tray.
If they feel smooth, try to put some tape on them and rip it back off.
This cleans the wheels. Also try a new pack of paper and check if it\'s set to plain paper and not to heavier or coated paper
May 30, 2013 | Brother MFC-7840W Multifunction Laser...
Getting a constant "Paper Jam 071-100" error when printing from Tray 1 (no jam found).
You need to replace the paper pick up, feed rollers and separation sub-assebly.
Nov 27, 2012 | Dell 3115CN
Paper tray at front of scanner will not lift. Scanner has been reset multiple times and computer rebooted as well. Error msg= unknown error canon DR-6080/7880/9080C driver versioin 1.3.10502.17001 (-4523)
Disconnect the scanner from the Comp, Try 'page counting'. If the papers go through, then you know feed mechanism is okay. if the tray is not lifting, then you have a problem. Use Qumatool software and check if the tray is lifting. If the scanner tray if lifting then the motor is okay, if not, the lifting motor may need a check.If the motor is okay, but tray not lifting means the sensor in the paper tray is faulty. Check this out.
S. Mohan, Chennai, India
Jun 30, 2010 | Canon DR-9080C Path-Through Scanner
Msg is paper jam when there is no paper jam
I had what seems to be a similar problem and the issue was that the rubber "feet" that grab the paper weren't grabbing anymore. So, I constantly got a paper jam reading. I read elsewhere to wipe some glass cleaner/ammonia on the "feet" so that they become "sticky" again. When I did this, the "Feet" or rubber semi-circle parts that rotate around a metal bar then started to correctly grab the paper again and the error stopped.
Aug 31, 2009 | Konica Minolta magicolor 2300DL Laser...
Epson RX680 Scanner Error msg and noise
If you only purchased it on the 8/9/09 then it is still under guarantee so the cheapest fix is return it for replacement.
Aug 24, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Load paper error on and paper is loaded
you have probably knocked sensor out of position at the paper feed in area. To check you will need to remove the paper tray completly from machine, then tilt machine up in front and look where paper is fed in there should be like a black flag in that area. it is the sensor that tells machine there is paper.
Apr 15, 2009 | Ricoh Aficio 1013F Copier
Error msg: Paper tray empty or jam, when there is not
Clean The Paper Feed Rollers Using The Unit's Operation Panel Ifthe paper feed roller is dirty, paper is not fed properly because thepaper feed roller slips. Cleaning the paper feed roller could resolvethe paper feeding problem. Please follow the instructions below toclean the Paper Feed Rollers directly from the unit. Caution:Since the cleaning process wears down the paper feed roller, performthis procedure only when necessary and no more than three (3) times.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for additional information.
  3. Press the <Menu> button.
  4. Use the right / left cursor button to select [Maintenance/settings] press the <OK> button.
    Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 5.
  5. Use the right / left cursor button to select [Maintenance] and the press the <OK> button.
  6. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  1. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  2. Tocheck if the rollers are clean, load a sheet of Letter-sized plainpaper in the same paper source you selected in step 2, and press the<Open> button.
  3. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Sourcesetting in the printer driver. If the option is not set to 'Paper FeedSwitch', paper will feed from the source selected in the driver.
Nov 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon 710i
Can you look into the paper tray and actually see if the feed rolls are turning? You may have either a bad paper feed clutch, or the solonoid that releases the feed rollers is bad.
Also the paper tray should move up and down when the paper feeds to move the paper against the rollers. Up to feed down to eliminate paper drag. One of those fingers that raise the tray may be binding against the bottom of the tray not allowing proper movement.
If you can get a flash light and observe what is going on. Then let me know.
Mar 21, 2008 | Canon FAX-L1000 Plain Paper Laser
Lexmark c510 241 paper jam error
I agree - the guides inside the paper feed tray must be EXACTLY aligned with the paper size. This fixed my problem.
Feb 06, 2008 | Lexmark C510 Laser Printer
HP4 and PC LOAD LETTER MSG (and there is paper)
Hi, I assume you can run paper thru the manual feed without any problems? If so the paper sensor that detects the paper in the tray has either broken or fallen off! If you take the paper tray out and tilt the printer a little bit on it's back you should see a sensor that will swing back and forth its' solid black/plastic . The sensor is very cheap and I'm pretty sure this is the problem> Good Luck!!
Nov 29, 2007 | HP : HP4 Laserjet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
49 people viewed this question
Ben Johnson
