Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Picture goes goofy in 1080i
How do I describe this? Well lets start with known facts. The HD source is a DirecTV HD H21 receiver. Input connection, HDMI to DVI Converter. During the setup of the DirecTV receiver, it tests to see if the TV supports all resolutions, 480i,p 720p etc... It's telling me that it only supports 480p and 1080i, even though the TV will display the other resolutions, or at least it did. Well anyway, to the problem at hand. When tuned to a HD channel, and the resolution on the receiver set to 1080i, the picture becomes somewhat skewed and blurry as if the convergence is messed up. At this point the auto convergence will not run. It starts then it quits. I can adjust manually, but there is no change in the picture. Auto convergence will run just fine under lower resolutions, but not while in 1080i. But when I switch back to 480p (on the same channel) the picture becomes just fine. Any ideas?
As a side note. When using my old HD receiver an RCA DirecTV unit, I would have similar problem. But it self corrected in an odd way. Let me explain... When the picture was skewed as mentioned above, I would enter the receivers menu, then I would exit the menu right away, the screen would go black for a couple seconds as if the receiver was resetting or something, and come back on just fine in 1080i. It would only do that when the picture was messed up. Other wise entering and exiting the menus worked just fine. But with this new DirecTV receiver, the goofy picture stays. There is obviously something wrong in that TV. I can't blame the receivers. This is a goofy one. What do ya think?
  • JerryKlr Jan 02, 2008
    Thanks for the comments. It's not a DLP unit. The TV still does work, but since my first posting, the convergence doesn't work under any resolution now. The repair tech was here and ordered a new convergence board. I picked it up and installed it. It made no difference what so ever. The problem must be else where. He's coming back today today in fact (1/2/08). I hope he brings test equipment this time. Last time was just a guess on his part. I'm not to sure on this guys abilities. I think a LCD is in my near future.
  • Anonymous Jul 22, 2008
    I am havin g the same problem with my Samsung 42" rear projection. I also have Direct TV and it does the same thing you mentioned--gettin g distorted only in 1080i. All other resolutions are fine. What gives?
    President:
  • 1,314 Answers
If that's a dlp unit they are garbage ive had two and both died in same manner in less than a year one the bulb blew on in three months after purchase then went blank and started making a high pitched squealing sound had to argue with rca cust support after repair shop said they could not fix it rca finally sent me a new one but with less features after i argued with them for another three that one did the same thing after three months now rca wont even talk to me and ive got a 100lbs paperweight that does nothing i was told it was the light engine at a cost of around a grand for part so don't waste your money on a repair shop mine is still sitting there blank and i understand this is a common problem from checking the web just roll it in the back yard spend you money on one that will work im going lcd this time and i do houseld appliances not tvs so dont worry about rating me i like to pass this info on every chance i get just to help my friends at rca
Posted on Jan 02, 2008
How to Access Directv Apps?
DIRECTV TV Apps are FREE and easy to use. Just press the
right arrow button on your remote to launch the TV Apps dock,
select the app you want, and enjoy! TV Apps require a
broadband-connected HD or HD DVR receiver (models H21 and
higher, models HR20 and higher, and models C31 and higher).
Oct 19, 2016 | Televison & Video
Why can't i see 1080p programs on my directv hd dvr? The test on the hdr says my receiver doesn't receive 1080p. My tv is a Sharp LC-62C42U which is suppose to receive 1080p!
Your DVR can't detect whether your TV can do HD or not. If the message is stating that your receiver (which is your DVR) can't receive 1080P, then you'll need to contact DirecTV for assistance. You may need to replace your DVR.
Mar 01, 2011 | Sharp LC-62C42U 42 in. LCD TV
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
I have a Sharp Aquos LC-30HV4U which is supposedly HD ready. I am a Dish Network satellite subscriber. I do not know what to do to make this HD ready set receive HD signals.
Your reciver is already set for the hd. Alls satellite programing and cable already come in hd format. You can also get any info here.
http://www.dtv.gov/
Good luck and please rate FixYa!
Apr 07, 2009 | Televison & Video
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
Screen goes black and resets during HD shows
I just posted this to another Sony owner:
Another point; HD Ready does not mean that it is HD compatible without the addition of an optional part.
The title only implies that it can be adapted to HD reception.
If you did not purchase it with the set, check your user guide to see what you need to make it whole.
You may have to seek this add-on on eBay since it is not guaranteed that Sony will still offer it.
You might want to check this:
Technical Details · 53-inch HD-ready rear-projection TV (doesn't include HD receiver); 48 x 57.5 x 25 inches (W x H x D)”
From: http://www.amazon.com/Sony-KP-53HS10-53-Inch-Projection-TV/dp/B000050FGB
Aug 31, 2008 | Sony KP-53HS10 TV
Have you already tried to power cycle all the devices? Unplug the power cable on all your devices for about 1 hour then plug it back in. Check if that fixes it.
Code for directv receiver
It looks like teh H21-200 is made by Samsung. Searching the DirectTV site gave me the code 00001 which worked for me.
Jeff
Jan 03, 2008 | RCA RCU810 LCD Remote Control
Picture stretch top/bottom for 1080i HD input
First thing to look at would be the source, make sure that this source whatever it may be is set to display a 16X9 format. Your set may simply be showing what it see's and it may be seeing the 4X5 format and giving you a problem
Jan 02, 2008 | Toshiba 57H81 57" Rear Projection...
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
217 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
