Question about Soundstorm D400.2 Car Audio Amplifier
Soundstorm 1600 Watt Car Amp
I have had this amp hooked up before but this time it says protection mode and will not work itis impairitive thatI getthis to work if I do I get an entertainment center for helping out my friend.
  • 631 Answers
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Posted on Dec 15, 2007
What does my protection light come on after hooking everything up
There is something shorting out the amp. What you will need to do is disconect all wires and hook up one at a time. Connect ground, !2 volt and remote see if amp turns on ok. If it does try connecting each speaker seperately to see if either one sends the amp into protect mode. Then connect the rca. See what causes the amp to go into protect mode.
May 08, 2013 | Car Audio & Video
ZX 1000.1 amp stays in protection mode
It is normal for them to go into the protect mode, If the speakers are not hooked up to it,
Nov 09, 2012 | Kicker Car Audio & Video
Got a problem with my car amp.Everything was working fine until 2day.Amp goes in to protection mode.Jumps from power to protection indicator every i would say 3 seconds and each time it goes in to...
Ok check the remote wire running from the headunit to the amp should be giving v12 feed whiles headunit is on.
check or change grounding position.
take cover off the amp as the circuit may be over heating.
Sep 22, 2010 | Car Audio & Video
I hooked up 2 capacitors into my amp and every time I put power to it the amp shuts off and 10 seconds later a red light comes on for 5 seconds and the amp don't turn on, basically it goes into protect...
Well, I have no idea why you would have two capacitors on a 500 watt amp but, did you charge the capacitors? Have you tried the amp without the capacitors? What size power wire are you using?
Sep 20, 2010 | Kenwood KAC-9102D Car Audio Amplifier
My amplifier turns protection on about a minute after working fine
See the link below for a description of protection mode. For your specific case, there is probably some DC voltage drift thatis causing the protection circuit to kick in. A trip to the service shop is needed.
Dan
link: http://www.fixya.com/support/r5390728-protector_means
Aug 27, 2010 | Kenwood Audio Players & Recorders
Protect mode
Protection circuit.
Checek the wiring of the amp and speakers, don' forget to look for shorts at the speakers. Make sure no wires are touching each other
Apr 30, 2010 | Volfenhag 1600 WATT CHROME AMP AMPLIFIER 2...
FUC% the protection light
i had a similar problem with my amp (although a different brand). Check you ground connection and make sure it's not grounded to metal with paint covering it. This is NOT a solid ground connection. You must remove the paint then reconnect it. Without a solid connection to ground, it cant run for very long without going into protection mode. Hope this helps
Jul 27, 2009 | Soundstorm Force F2800 Car Audio Amplifier
Speakers cut off when bass goes up
probably the amp going to safe or protect mode judging by the fact that you have 3 subs wired to it i would say it is not 1 ohm stable try disconnecting 1 sub and see if it still happens this will be running a 2 ohm load rather than 1 if it stops happening then you need to figure out a better wiring configuration that will work with your amp.
Jul 03, 2009 | Kicker ZX400.1 Car Audio Amplifier
Protection mode on my amp
YEA CHECK THE OHMS ON THE SUB TO MAKE SURE THEY MATCH UP TO THE AMP JUS SOUNDS LIKE THE WIRING IS OUT OF PHASE.
Jun 15, 2009 | Pioneer GM-7200M Car Audio Amplifier
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
Soundstorm D400.2 Car Audio Amplifier Logo
223 people viewed this question
Top Soundstorm Car Audio & Video Experts
hoyzee1
Jim Goldsmith
Jim Goldsmith
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
