Question about Samsung SlimFit TX-S3082WH 30" TV
No picture Movers pulled the CATV connector from the back. I took the back off and was able to resolder and anchor the connector. Put the back on and get the red light on the front when I power up but it will not power up the CRT.
  • R. W. NICHOLS Mar 16, 2008
    tv went black while i was watching it. unplugged it and plugged back in,red lite came on but no picture or sound. only could turn off w/remote
  • 236 Answers
Your unit still on standby when red lite is on?
Posted on Mar 18, 2008
  • Redentor Rivera Mar 18, 2008
    still the same when you turn on using the remote controller?
A bolt won't tighten all the way just keeps spinning, but it also won't unscrew out of the wall. What should I do to get this bolt out without stripping the thing?
Yes just pull it out - it will pull out the anchor on the screw, then replace it with a new larger anchor and screw. or fill the hole and re drill a new hole the right size.
Feb 06, 2016 | Home
Unit will not pull up the anchor
First, put a volt meter across the winch's power terminals to verify that the voltage is not dropping several volts when comanded to run, indicating a bad cable connection somewhere. Anchor winch's pull alot of current from a battery.
For a test, use car jumper cables from a good battery to the winch to see if it runs better.
Oct 18, 2009 | Boating
Need schematic for home universal
You can get that at they bought the company years ago. This should help you.
Oct 01, 2009 | Exercise & Fitness
The CATV connector on my Mitsubishi tv is broken off
This is the connector for the tuner. This repair must be done by someone who knows how to solder. But, if you have a Cable or Satellite box and this TV has AV connectors on the can use those and do not need to repair the TV tuner. If you do not have cable or satellite you can also use a VCR as a tuner. Just put the cable into the VCR and come out of the [VCR] AV outputs into the TV AV inputs.
Jul 06, 2009 | Televison & Video
Broken catv connector. need a repair in area El Cajon Ca.
if you can take the back off of it and use a soldering iron you can fix it yourself and save u money!!! just see where the connection came loose, heat it up and re-solder it
Apr 17, 2009 | Televison & Video
Broken CATV connector on the TV
you'll have to take the tv apart un solder he connection go to radio schak and see if they have the part . resolder put tv back togrether done
Jan 04, 2009 | Sylvania 6419TC 19" TV
Kenwood KRA 5050 No power
I think the movers mishandle your unit that why it happen like that.It needs to reheat or resolder because the solder holding the spare parts are loose or crack,so when it resolder already performance will come again .That all Txjay , just for now.
Jun 18, 2008 | Kenwood VR-405 Receiver
No recption pass channel 12
judging by the year, this set should definitely be cable ready. check the front of the tv if it has a control panel for a switch that says catv/normal or something similar, if it does not have that switch, check the settings via the remote.
the channel a connector may require an adapter depending on the type of connector. i had an old tv that required an adapter in order to plug the cable coax into it, it resembled an rca connector and is used on some older tv's in place of a screw on connector.
if all else fails, your cable company should be able to provide you with a tuner/converter for free or minimal charge.
i hope this helps,
Nov 16, 2007 | Hitachi 60SBX78B 60" Rear Projection...
Cable connector broke off at solder for GE 27GT722
Common problem Order 215543 from a company such as Union Electronics..1-800-648-6657 Use only the orginal, the replacement melts to quicky from the heat of the solder. They don't have a minimum order. Also make sure all the tuner shield grounds are resoldered. Be careful. easy to solder short.
Jun 28, 2006 | GE 25GT240 25" TV
Samsung SlimFit  TX-S3082WH 30" TV Logo
67 people viewed this question
Jerry Greenberg
Jerry Greenberg
