Question about HP Compaq FS 7550 17" CRT Monitor
Computer crash no sound
Moniter on the computer was turned off and I thought the computer was turned off. I turned computer off and on several times. They told me the computer crashed because I turned it off and on to fast. they got everything back except the sound. The computer keeps saying the speakers are not connected. I have disconnected them and put them back on and still get the same answer. Please help.
  • sleepy55 Dec 14, 2007
    this computer is a compaq 7550
  • sleepy55 Dec 15, 2007
    Almubarmej send more information. Don't understand advice.
Check the printed circuit board, check for cut lines
Posted on Dec 15, 2007
  • Arthur sayo Dec 16, 2007
    check speakers if there is a continuation (resistance)mostly 8ohms, if ok check for amplifiers B+ or power supplly which is approximately 9-12 V DC
Last weakend i drove about 400 miles ,the truck ran smooth all weekend untill we got off the freeway it started idling very rough ,i thought it was going to shut off so i cept the idle speed up when...
YEA, REPLACE EGR VALVE, ALSO, REPLACE AIR & FUEL FILTER, OXYGEN SENSOR SHOULD ALSO BE REPLACED !!!!! DON'T KNOW WHAT YOUR CODES ARE @ THIS TIME, BUT TAKE TO A AUTOPARTS STORE, THEY CAN PULL THEM & LET YOU KNOW ! MISFIRE MAY BE YOUR KNOCK SENSOR, ACTING LIKE A MISFIRE . EGR VALVE IS KNOWN TO GET CLOGGED UP, SEVERELY ! MAP SENSOR MAY BE ACTING UP ALSO, ALL SENSORS WORK TOGETHER, IF ONE STARTS GOING BAD THE OTHERS TRY TO ALONG WITH THE COMPUTER TRY TO COMPENSATE, YOU ONLY NOTICED IT AFTER FREEWAY, BECAUSE @ HIGHER THROTTLE, IT WILL NOT SHOW UP, THE TRUTH CAME OUT WHEN YOU GOT OFF THE FREEWAY ! VERY CONDISENDING , ESPECIALLY WHEN YOU THOUGHT YOU WHERE HELPING TO BLOW OUT THE ENGINE TO RUN BETTER,. YOU SHOOK SOMETHING LOOSE. BETTER AFTER FREEWAY, THEN ON IT.
Mar 24, 2013 | 2005 GMC Sierra 2500HD 4WD
LG Flatron E2042. Brand new. New CPU. Windows 7. I plugged in my new monitor today. Does not turn on automatically. But when I do turn it on I get an error message. D SUB POWER SAVING MODE and tur
Your new moniter may not be compatible with your computer. I have an Emachines that won't take a flat screen. I have to use a big bulky moniter because it says not connected even thought the hookup fits the back of the tower. That might be your problem. Did your old moniter work correctly?
Nov 15, 2012 | Computers & Internet
My dell moniter 2010f flickers all the time. I have another moniter on that uses the same card by does'n flickers. I also pugged the dell in by its self and it still flickered. l also down loaded...
Sounds like an issue with the backlight in the monitor. Usually the backlight is built in to the LCD panel so there really isn't a way of fixing this unless you replace the panel.
Please rate my solution to show your appreciation!
Jun 02, 2011 | Dell ST2010 20 inch LCD Monitor
I have a samsung Syncmaster 2343 and I can turn it on just fine and my computer recognizes that it's hooked to a moniter but the moniter shows the screen for a few seconds and then it all goes black. It's...
If your up to opening the monitor it would do you well to look. It sounds close to what I experienced.Refer to Problems with Samsung SyncMaster 2053bw for info on opening.
Nov 11, 2009 | Computers & Internet
Three days ago, my moniter would light up when I awoke the pc and then it went black. Turning the power button on and off three or four times would get the moniter to stay on. Yesterday, I noticed that I...
your pc is in need to open inside but this time call an assistance to a technician to fix it... dont be a hero to your PC... u cant use it until you hire technician on that... i tell you!
Jun 18, 2009 | Computers & Internet
Moniter very lightly flashing
Problem was not solved. I am returning to Samsung. Thanks.
Jan 05, 2009 | X2Gen MG19MY 19" LCD Monitor
Cant get My dell Dimension b110 to boot no display on moniter!
Which Ram u r using ( DDR, DDR2) , and whats the make of u r PC, as per my understanding Ram is not compatible, is old RAM is still working.
Nov 01, 2008 | Dell Dimension™ B110 PC Desktop
Get Moniter Speakers Working
Hello First of all you need a sound card on your computer with a Spk. (Speaker) or Phones (headphones) Out Jack it might be a symbol of a small speaker or headphones. You have to be sure you are getting a actual sound output signal from this sound card too. If the sound card is not working your moniter speakers would not have a signal to drive it. You also need a 1/8" Stereo 2 male stereo plugs on both ends, one end plugs in back of moniter other plugs in back of computer like I mentiond above. Make sure your Mute button is not selected on your computers volume button usally at bottom right of screen. Make sure the volume buttons are up to aprox 3/4 up also. Then for last on the moniter look in the menu i think you might have to keep pressing the menu button but i kind of forget now but its a Spk setting and volume setting in this speaker setup within the moniter as well make sure this is turned on and set at a higher volume level as well. Thats about all I can say without taking the moniter apart and checking the jack and wires and speakers. I would suggest you take it to a electronics or a tv repair or computer repair person to go any further then this. Hope you take time to read all of this I tried to put every step in here to help anyone out with this problem. Thanks for reading. Ken T
Nov 08, 2006 | Liquid Video A170E101 Monitor
HP Compaq FS 7550 17" CRT Monitor Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
