It's different connector types for fibre cables(SC is different to LC) - it means that you have SC on one side and LC on the other. Google to see what they look like.
Hello
The SC (Super Charger) needs oil and it has a recessed threaded plug on the SC casing to check the level, when the oil is correct it should just come to the edge of the fill hole plug threads. The oil is a special lubricant made especially for Super Chargers and can be purchased from the dealer, each manufacturer has there own formula of SC oil, so although other SC oils will probably be OK why take the chance, use the SC lube from the Aston Marin dealer if you have a dealer near by. If no Aston Marin dealer is close the next best SC oil can be purchased from any GM dealer.
This error code SC 211 not exist.Exist SC 2-11 is the communication problem.For reset the SC codes following the procedure:enter in the service mode (press total clear key-1-0-7-Clear keyhold down more 3 sec.Enter SP 5-810 SC code reset and select `1`.Then hold down the original type key and the OK key at the same time.This does not require the main switch to be turned OFF and ON.
